Zf6
Old Mar 16, 2022 | 09:25 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default Zf6
Anybody put a ZF6 in an84-88 using a dana 36?
Old Mar 16, 2022 | 09:29 PM
ajp01's Avatar
ajp01
Oh, I'm sure an 84-88 to ZF6 conversion has been done by someone here...
Old Mar 16, 2022 | 09:45 PM
coupeguy2001
Default Zf6
Yes but with a dana 36. Not a 44. Torque arm length, driveshaft length, yoke, etc
Old Mar 17, 2022 | 08:53 PM
coupeguy2001
Default Zf6
Ttt
Old Mar 21, 2022 | 01:05 PM
coupeguy2001
Ttt
Old Mar 21, 2022 | 01:28 PM
topfuel67's Avatar
topfuel67
A huge problem would be the gearing. The first gear ratio in the ZF6 is 2.66 which is almost a 2nd gear ratio. So if you use a Dana 36 most are 2.59 and the rare ones are 3.07. Either one is too high of a gear for a zf6. It would feel like you're starting off in 2nd gear. Plus the zf6 has a .5 o/d in 6th. The 2.59 gearing would make 6th gear useless until 90 mph. That could be a salt flat high speed car where you reach over 200 mph but need someone to push you to get going. The first 89s that came with the zf6 got the 3.33s and then went to 3.45s pretty quickly as the 3.33 wasn't a low enough gear.
As far as the drive shaft and c beam lining up that would be another issue. Is the ZF6 the exact same size as the auto? That's the only way the c beam would line up from the auto. The D44 snout is is a different size than the D36, so the c beam from the manual would not line up using the D36 unless it happens to be the exact same difference in length that the auto/manual transmissions are. The drive shaft you can have a little room for difference as the slip yoke has play, but not too much.
Old Mar 21, 2022 | 01:40 PM
WVZR-1's Avatar
WVZR-1
A person could assume 'MAYBE' that because the D36 is there you could reuse the D36 C-Beam, a drive shaft would require a modification of a correct ZF to match the length and fit to the ZF trans. There certainly is the 'MAYBE' but if this was to be a long term driver with reasonable performance reliability I cant imagine a person not doing a D44 at the same time. There's considerable modification required to do just a ZF install in an '88 and earlier. The D44 expense would 'MAYBE' be considered 'MINIMAL' if a person is considering the build.
I don't quite get the 'thread bump'!!! Just 'DO IT' and tell all.
Old Apr 6, 2022 | 12:10 AM
coupeguy2001
Default Zf6
There is an 85 that already has a ZF6 installed in it to be the donor car.
the Dana. 36 in my car is out of a 12,000 mile 96 that a barn fell on and the insurance co. Totalled it.
It now has 14,000 miles on it and since it’s so low mileage, i thought I would like to keep it.
it has been in my car for about 4 months, no noise, leaks or problems, but i did inspect it and change the sealant at the batwing and replaced the gear oil with synthetic positraction gear oil.
my C5 has a 6 speed in it, and i enjoy that driving experience as well as my 57 chevy truck with the 4+3 with manually controlling the overdrive.
( 3rd overdrive is 200 rpm lower than 4thgear without the overdrive on)
auto transmissions are the absolute best in traffic, but don’t afford total control of the powertrain.
Old Apr 6, 2022 | 02:40 PM
87bob's Avatar
87bob
Veteran: Coast Guard
The Zf is a good trans but expensive to rebuild the parts are not cheap. so if you thinking of buying a used one get it CHEAP. You’d be better to buy a car with a ZF. C4’s are cheap right now.
Old Jun 9, 2022 | 01:48 PM
ACMX92's Avatar
ACMX92
2026 Restomod of the Year Finalist
2026 Corvette of the Year Finalist - Modified
2025 C4 of the Year Winner - Modified
2021 C4 of the Year Finalist - Modified
As far as I know, there are only two C-beams for the C4 Corvette. One for the Dana-36 and one for the Dana-44. Since the automatic C4s did not come with a D44, the c-beams are commonly referred to as an automatic c-beam or a manual c-beam, but it is actually the differential that necessitates the different lengths, not the transmission.
As others have said, you can absolutely swap a ZF6 into a car with a D36. All you need to do is change the driveshaft yoke to work with the ZF6. Somewhere I read that a TH400 yoke will work but not positive on that.
Something I have learned over the years, when taking on a big project over a longer time frame, sometimes it is best to just do one job at a time. Even if you have to re-do a few things when you move on to the next project.
If dealing with a D-36 and tall gears for a bit means getting your ZF6 swap done and driving sooner, I think that is worth it. You can always swap in shorter gears or a D44 later on down the road.
To Zf6
