Injector Question
Old Apr 28, 2022 | 10:28 PM
85corvettejeff's Avatar
85corvettejeff
Default Injector Question
I have a stock 85 with an automatic , i have these injectors installed ,are these too big for a stock motor? no drive ability issues just wondering ?
26LB Bosch Upgrade Set Of 8 Fuel Injectors
Old Apr 28, 2022 | 11:17 PM
W2vette's Avatar
W2vette
Cruising
I think stock injectors for an 85 are 24lbs
Old Apr 29, 2022 | 08:48 AM
Incorvettei's Avatar
Incorvettei
I believe the factory injectors were 22’s. I don’t see an issue using 26’s
Old Apr 29, 2022 | 09:14 AM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
incorrect. stock on 85 were 24lbs bosch. all black in colour. 1 year only for 24lbs.
Old Apr 29, 2022 | 10:49 AM
bjankuski's Avatar
bjankuski
They are a little big but will work fine for the most part. You could be giving up some power at WOT if the car is running rich since those injectors are 8% larger then stock but that needs to be determined by checking AFR and what the engine actually wants.
Your fuel trims could be checked to see how much the computer was correcting and that would give you a idea on where you stood.
in general it will probably be fine.
Old Apr 29, 2022 | 10:56 AM
vader86's Avatar
vader86
Stock 85 is 24lb/hr but rated at a lower pressure, so they're similar to the 22s in later years.
26lb would be a bit too much for the ECM to compensate for I'd think.
Old Apr 30, 2022 | 11:45 AM
Phobos84's Avatar
Phobos84
Think about a flex fuel car. Most run at least a 36 pound injector on a stock engine because of the extra flow needed. When you fill the tank with regular pump gas it runs just fine. So you can run almost any injector you want. As long as the tune is done for those injectors it will run fine.
Old Apr 30, 2022 | 12:48 PM
VikingTrad3r
Oil Producer
fuel trims (int/blm) will tell the full story. or just get 24’s
To Injector Question
