1995 Total Electrical Failure
Old Jun 11, 2022 | 09:53 AM
Ponykillr's Avatar
Ponykillr
2nd Gear
Default 1995 Total Electrical Failure
I have a 1995 ZF6 that went totally dead on crank. IT acted like normal for a fraction of a second, then total electrical failure. No lights, sounds, etc. as if someone just ripped the battery out of the car. battery is showing good, and no noticeable issues easily seen, no blown traditional fuses that I can find.
Old Jun 12, 2022 | 12:20 AM
pedricd's Avatar
pedricd
This happened to me and it was simply the connections at the battery… remove, clean and then firmly tighten the terminals and see if that does it.
Old Jun 12, 2022 | 12:47 AM
ToniJ1960's Avatar
ToniJ1960
Check the fusible links behind the battery also just in case its not loose or dirty battery connections
Old Jun 12, 2022 | 07:30 AM
PAINTER MAN's Avatar
PAINTER MAN
I just had this happen. Turned out to be loose battery connection.
Old Jun 12, 2022 | 09:58 AM
pcolt94's Avatar
pcolt94
There is no one fuse that will cause the car to be dead.
Most likely a battery terminal, seen that many times..
Could be battery, low possibility.
To 1995 Total Electrical Failure
