Top ball joint rivit hole diameter
Old Jun 26, 2022 | 02:04 PM
Woody2022's Avatar
Woody2022
3rd Gear
Default Top ball joint rivit hole diameter
Will someone tell me the diameter of the hole in the UCA for the rivit to attach the ball joint I want to drill out the factory rivit and need to know the hole diameter to get the right drill bit. Thank you and please respond
Old Jun 26, 2022 | 09:51 PM
Ark--C4's Avatar
Ark--C4
did you try measuring the new rivet diameter to determine the proper hole size?
What is the size of the hole in the new ball joint?
Old Jun 26, 2022 | 11:29 PM
Garand1's Avatar
Garand1
If the ball joint is going to be replaced, use a sharp chisel, or air chisel and cut the heads of the rivets off. Then, take the appropriate size punch, and knock the rivet out of the controll arm & ball joint. That way, you dont have to worry about the bit deflecting or drilled off center and damaging the control arm.
Old Jun 27, 2022 | 11:22 AM
Dollarten's Avatar
Dollarten
After you knock the rivet head off, like Garand1 says , take a center punch and locate the center of the rivet and drill an 1/8 inch hole through the rivet.
This will take much of the grip off the rivet shank and will allow easier removal
Old Jun 27, 2022 | 03:18 PM
jmgtp's Avatar
jmgtp
Not a direct answer to your question, but you may find post #19 in the following thread helpful.
https://www.corvetteforum.com/forums...-overhaul.html
To Top ball joint rivit hole diameter
