Hello, my 86 is running very erratic with the check engine light coming on at random but I don’t get any diagnostic codes from the ECM. Check engine light will just flicker when I try to get the codes. Car will start and stall or not idle but sometimes it idles fine and then touch the gas and it dies. Upshift arrow lights up when sitting still in park at random, when the check engine comes on while driving it’s like the car lost half its power. Car is bone stock with only 36k miles on it. Does this sound like the ECM is bad? Car has fuel pressure and spark. One minute it’s running fine and then I go to pull into traffic and if falls on it’s face. Thanks for any help.
Starting with the basics
Would focus on electrical issues as "flicker" is noted
--take off, clean and reattached all grounds and power supply wires
--if any in question--add additional wires as "testing wires"--remove at later date
--inspect all connectors--pull apart and re-attach--start and run car at every change--need to isolate exact locaton
--perform "wiggle test" of wires, wire harness and connections--
--disconnect one input sensor at a time, CTS, TPS, MAF/MAP, O2 etc and drive car--car should run--most likely "rich" and set corresponding code for sensor--
Keep all posted
Keep all posted
I’m going through the grounds and checking all the sensors but the fact that I can’t get the computer to display any codes and things like the upshift arrow popping on and off while sitting makes me think it may be an ECM issue. Is there any kind of diagnostics to test the ECM?
You need the factory service manual and there is a procedure. Mine is an 86 as well with only 12,000 miles. It was running like crap and doing weird things, flashing the SES light and only a couple of times actually set a code. Then the code went away after I saw what it was. Then it would flash the SES light several times without setting a code. Going through the test procedure for the code that it presented the one time it came down to a bad ECM. Changed the ECM out with one out of an 87 and all has been well.
I've been unable to get any codes out of it so far. I would think with the way it acts when I try to get codes from it that it must be an ECM issue but is there any kind of a test that can be run on the ECM? I do have the service manual.
