check engine trouble
Old Jul 27, 2022 | 11:46 PM
steveo’s 85vette's Avatar
steveo’s 85vette
Cruising
Default check engine trouble
just when i thought my problems couldn’t get any worse my check engine light came on. i went to read the code by putting a paper clip on connecters A and B like i saw in a video and whenever i turned the key into the on position my coolant fan starts up. anyone know why this is happening and what it could be. it only happens when the paper clip is in the code reader.
Old Jul 28, 2022 | 06:57 AM
CorvetteRules's Avatar
CorvetteRules
Did it read the code(s) ?
Old Jul 28, 2022 | 09:46 AM
pedricd's Avatar
pedricd
If you jumped the correct pins one of the things that happens is the fans come on full blast. That is completely normal when reading codes.
Old Jul 28, 2022 | 10:52 AM
vettespecial's Avatar
vettespecial
Fans will run during diagnostic mode A&B pinned togeather light should flash code (12) 3 times, normal then any codes there after.
Old Jul 28, 2022 | 03:01 PM
steveo’s 85vette
Cruising
oh alright then i was concerned because i didnt know if that was normal
Old Jul 28, 2022 | 03:52 PM
steveo’s 85vette
Cruising
so i ended up getting code 45 which is for rich exhaust indicator im not sure if my car being straight pipe affects this or if theres actually something wrong.
Old Jul 31, 2022 | 08:43 AM
FOURSPEEDVETTE's Avatar
FOURSPEEDVETTE
If you have the heavy duty cooling system option, you will have two fans. One in front of the radiator and one on the engine side of the radiator. The one in front of the radiator will not come on when pinning A & B. It's not run by the ECM. It strictly only comes on at engine temperature of 238 degrees and it only uses a temperature switch (sensor) to turn on. The fan on the engine side only comes on when pinning A & B. Completely normal that it came on when you connected A & B,
To check engine trouble
