Acceleration Issue
Old Jul 30, 2022 | 02:47 AM
Tokishiru's Avatar
Tokishiru
5th Gear
Default Acceleration Issue
I’ve been doing my own research for a while but can’t seem to find anything. If I’m turning, left or right, while either accelerating at a specific speed or if I nail it, the acceleration just stops for a few seconds and I’m not sure why. Any advice is appreciated, thank you in advance.
Update (08/10/2022)
I’ve cleaned the MAF sensor and the throttle plate and put some fuel injector cleaner in the gas tank, which made it run better (as expected) but I still have the same issue. I will try filling up the tank and see if that helps, if not, I will replace the fuel filter, maybe it’s clogged.
Update
I figured it out, it just seems that when the gas tank is around half full it does this, don’t think there’s really a way that I can fix this.
Old Jul 30, 2022 | 03:06 AM
Kilobuck84's Avatar
Kilobuck84
Have you noticed whether the issue is related to fuel level? If it doesn't happen when the tank is full it usually indicates a problem with the in-tank sock/strainer.
Old Jul 30, 2022 | 07:54 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Yeah....C4's are notorious for losing fuel at lower fuel levels....in hard turns. I fixed it by upgrading fuel pump...though maybe it was just a dirty "sock".
Old Aug 10, 2022 | 09:09 PM
Tokishiru's Avatar
Tokishiru
5th Gear
I’ll try filling it up and see if it’s that, and I replaced the fuel pump and filter when I got it but I will check again, thank you.
Old Aug 10, 2022 | 09:10 PM
Tokishiru's Avatar
Tokishiru
5th Gear
I replaced the pump and filter when I first got the car, but I will look at the sock and probably replace it, thank you.
Old Aug 11, 2022 | 11:00 PM
pcolt94's Avatar
pcolt94
So this may be a strange thought.
Are you sure the ASR is not activating. It will do it on fast turns and hold you back.
To Acceleration Issue
