1984 Corvette (cease fire) help
Old Aug 10, 2022 | 08:20 PM
Early-Fuel-Injection's Avatar
Default 1984 Corvette (cease fire) help
Good evening everyone,
It seems my car is in the shop more than on the road. From my research, some 1984 corvette were just problems from the get-go. Correct me if I am wrong on that. I've done everything underneath the sun to keep this car running. I bought the car with 45k in 2018. Here is the list. Where is the fuel line value I can press to see if there is pressure?
Current Mileage 49k
The current problem is start-up issues and cutting off while driving. I broke down today in the Chick Fil A drive-thru. Just had the starter replaced last week on August 5th (starter issues sent the car to the shop three times this year). Car started up and ran great for five days and now more problems. Right now it cranks but no start. Check engine light is solid. There seems to be a recurring issue with the starter wire coming undone underneath the car. Checked all fuses none are out.
New Altenator August 2019
TBI Tune-Up and Driver Side Injector - Cap & Rotor - air Cleaner - December 2019
General check up - grease fittings - check for leaks etc - power steer flush - transmission flush - March 2020
New ecm May 2020
May 2021 Spark Plug Wire
Valve Cover Gaskets & Oil Pressure Switch June 2021
Fuel Filter Nov 2021
New Transmission - Ignition Swtich - Dec 2021
New Fuel Pump & Starter August 2022
Thank you for your time.
Old Aug 11, 2022 | 07:45 AM
wilcar's Avatar
wilcar
Current Mileage 49k
New ecm May 2020
Tell us the area you live in.. probably some xfire gurus that can help you out,!
Old Aug 11, 2022 | 08:41 AM
FostersPerformance's Avatar
FostersPerformance
If it dosent start, just have someone crank it while looking for injectors spraying fuel, then go from there.
Old Aug 11, 2022 | 09:49 AM
Thank you! Im in South Carolina - Charleston area. A little update. I let it sit overnight. I went outside and took of the negative terminal and checked the alternator connections. I sprayed some cleaner in there. There was a little bit of build-up. The car started right up. I was wondering if it was a fuel issue. I'm nervous to drive it now because it could breakdown. I'm wondering if the alternator is going out.
Last night I was reading through the shop manual and Haynes as well trying to pinpoint the issue.
Old Aug 11, 2022 | 09:50 AM
Thank you!
Old Aug 11, 2022 | 01:01 PM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
This IS your best friend when owning a CFI corvette. It's worth its weight in gold.
84 GM Service Manual
Old Aug 16, 2022 | 11:09 AM
Orion2011's Avatar
Orion2011
If I had an 84 with the Catch Fire/Cease Fire injection I'd seriously consider an LS swap.
Old Aug 16, 2022 | 12:56 PM
Buccaneer's Avatar
Buccaneer
OK, that's just crazy talk for this issue and MUCH more expensive in the long run and not necessarily a simple task.
First off, there isn't a schrader valve for the fuel pressure like the 85 vette and up. CFI NEVER had that option for FP from GM. You measure the pressure in-between both throttle bodies, how you do it, is your decision. 13psi works just fine on ANY stock CFI motor, that's a GM high side spec, not mine. The manual I mentioned above IS what you need to get if you want to keep and or work on your CF and keep it running properly. Once you get things squared away, they run like the energizer bunny... Getting it there is usually the issue for the first time guys. GL
One last comment. The shop that you take your vette to "may not" know what they are doing with CFI and "may" mess your car up further. It is a chance that this may happen. There are NOT many around that know how to work on CFI even though it is a simple system. DO NOT mess with the TB adjustments unless you are completely familiar with them and know what you are doing or you WILL mess things up even more.
Old Aug 20, 2022 | 11:33 AM
I was thinking about doing this!
Old Aug 20, 2022 | 11:55 AM
Thank you for the info! Quick update. I went out this morning after a few days of letting the car sit and it started right up. Ive been reading in all of my service manuals trying to find something on this. I think it maybe over heating.
To 1984 Corvette (cease fire) help
