I’ve seen a common purchase for the stock LT1 TB air foil mod, I have an aftermarket 52mm BBK TB, will the air foil piece work with my TB just as it works on the stock 48mm?
All the BBK's I'm aware of have the airfoil cast in to them. If we are talking about the same unit then it's not needed and there's no place to attach it anyway. On stock TB's I always put them on. No they don't do a lot but they do something and they are cheap.
Agreed with all
BKK and most performance TBs. The airfoil is built in. just not perfected. My knifeblade 58mm BBK port and AF knifeblade
If you had a stock TB. And found a AF for a few dollars it would help out higher demanding CFM
Looks like binoculars.
May the torque be with you!
