L98 Not running right.
Could the engine computer be bad now? WTF, I dont need this! Car has been off the road for over a month now, I need to drive it! Anyone have an engine controller do this? It is NOT the original ECM, and I certainly dont have a spare. I do program my own PROMs, and yes i swapped that out with the same results.
I am thinking, that I put this all togethor correctly, the first time, but now I have a new problem! Any ideas?
Mike
You mention your ECU / prom. What happened to the OE. ECU. We will assume you have the OE prom.
Ps. What is the fuel pressure.
The only good thing I can say, is that this whole problem, started with my car sitting in my garage!! So, no tow-job was needed to get it home!
Last night, spent some time with my FSM, reading about the timing. May have found something to look at. I should be able to check it out today. Stay tuned!
Engine still won't run with the ECM connected. Pulled the timing connector, and it will idle fairly decent, hunting around a little, but I think it was like that before. Checked base timing, and it was right on 6deg BTC. I need to phone a friend on this one!
I'm really not looking forward to replacing the ECM!
