95' Vette A/C charging
Are you replacing a known bad part, or just shot gunning a bunch of stuff just because.
Non usage can cause seals to leak. But if you don't know where a leak specifically is, I would not rip it apart yet.
If this was me, I would first put a set of gauges on it and see if there is any pressure at all. Because you may just need a recharge and once you open the system it then needs to be evacuated. Not a big deal you just need a pump, hoses (gauges) and some experience.
The system holds about 2 cans of 134 (forget exact amount) when empty but will take less on a re-charge.
Once you open the system and replace hoses and accumulator you need some oil and it turns into a much larger job rather than a re-charge.
So if a system is opened, a vacuum pump, gauges and Freon is all that is needed. No special equipment but additional skill is.
And on a car that sat for couple years might not be a bad idea to add some dye just in case a leak has to be tracked down.
1. Replace the orifice as well (it's a sub $20 part, and it can get clogged up - it MAY even be included with the new receiver dryer).
2. When you (or a shop) goes to charge the system - the first step is to pull a vacuum on the system. Before starting to put in the R134a - add in a little dye, that way if a leak does develop - you can find it fairly easily.
With respect to actually doing the refill - you can buy a gauge set for about $50 and a vacuum pump for about $100. You might want to see if there is a local place that will do the charge for $50 or $60. The actual R134a is running a bit less than $10/lb, so your car will use less than $20 of R134a and the machine is pretty much automatic - hook it up - enter the amount of Freon to be dispensed, and hit GO. Come back 20 minutes later and it's pretty much done.
Not too long ago I replaced the evaporator and the accumulator on my 94. So this is fresh in my mind as exactly what has to be done.
1 - As said by me and above, put in dye. But it takes a while to show up unless there is a massive leak. And it has to circulate which means adding enough Freon to run the compressor and that’s almost a re-charge. If evacuation leak down test fails, you usually don't put in Freon, it's not ready. The dye is for the future cause some leaks take a while to show up. You fix it all first before adding Freon.
2- The orifice tubes are real cheap. I bought a five pack for a few dollars from AZ. The tube is in the evaporator. I borrowed a orifice puller from AZ but on our cars it physically will not fit in there to get it out. I actually made my own just for this purpose because the pipe is real close to the evaporator. And also, if you try to get it out with a long noise and break it, you are in deep deep poop. If it comes out easy, that would be nice.
I used my tool to install it in the new evaporator, but when I took out the old one from the old evaporator, the screen was real clean. So use you own judgment.
If however, we have a leak, and the machine "locks out" the inability to add some refrigerant makes finding the "leak" (particularly a smaller leak) difficult. The two primary ways to find a A/C system leak are by injecting dye and running the system (then looking for the dye), or by using a refrigerant sniffer while running the system. Of course - in order to run the system - you need to have enough pressure in the A/C system to convince the pressure switch to run the compressor (or you have to bypass the pressure switch - which sounds easy - but in some cars the Compressor is controlled by the car's computer - and it is difficult to convince the compressor to run when the pressure is too low).
The above is why SOME Pro's that do a lot of HVAC work - ALSO have a standard charging manifold and a vacuum pump - so they can manually inject dye, and manually push in refrigerant - so the compressor will run and circulate the refrigerant - so they have a halfway decent chance of actually finding the leak - so they don't just blindly throw parts at the problem.
