4+3 only goes into 3rd but will go into reverse?
I was trying to downshift from 3rd to 2nd for a ramp, but couldn't get it into the lower gear. I put it back into 3rd and after the ramp it shifted to 4th just fine. I managed to get almost all the way home without having to slow much, but at a light I could not get the shifter into first OR second. I limped home using only third and after parking it tried to row through all the gears with the engine both on and off. No dice -- I have no neutral or any side-to-side motion UNLESS I use the reverse lockout. The clutch works; I can start the car with the pedal in, but as I slowly release it in what SHOULD be neutral, it creeps forward. I also noticed that there were bubbles in the clutch hydraulic fluid after the drive, telling me I probably boiled it at some point, but they've settled out by today and the problem still persists. The stick is hard to move even with the clutch depressed, unless I'm going into reverse.
It's going to be a while until I can put it up on stands to look underneath, so I'm trying to get a list of things to check. I assume linkages should be the first thing. Bushings? Other things? I would prefer not to drop the transmission if I don't have to (no lift, so clearances to work underneath are rather tight)...
Any other thoughts? This has been a VERY expensive month for car repairs on our daily drivers; I can park the Vette for a while if I need to but if it's something simple I'd rather fix it myself.
Thanks in advance...
[RICHR]
https://www.corvetteforum.com/forums...alignment.html
[RICHR]
*** If someone had a shifter 'out of the car' maybe they could confirm the width of the required device,
@Ray Quayle or someone else maybe can put there hands on the one left behind on the line @BG
Which nut got loose? One on the threaded rod, or one of the levers on the side cover? Knowing this, I can write instructions.
I *may* have fixed it, though. I was back under the car trying to find the neutral-adjustment (can't get to that from inside OR outside without destroying the transmission tunnel...) and realized that the lever and arm were in the third-gear position even though the shifter handle was in "neutral." So I loosened the nut again and while doing that the rod POPPED forward into actual neutral. Tightened it up again but not fully tight (I'll need to hold the rod in place so it doesn't pull again) and when I got in the car I was able to row through all the gears again.
I'll crawl back under there and give it a better tightening tomorrow and then put it down and try running through the gears more.
[RICHR]
Sounds like you have it fixed. Cool.
And just to be clear, I replaced the missing lock washer before reinstalling stuff...
[RICHR]
