LT4/Hotcam question (again)
Old Jan 8, 2003 | 02:17 AM
Hamert's Avatar
Hamert
Default LT4/Hotcam question (again)
I have a '96 LT4. Can I just order the hotcam itself or do I need the whole kit? My car already has roller rockers being that it's an LT4. If I could just order the cam over the whole kit it would save me a ton of money. Do I really need the whole kit or will this do?:
GM PART # 24502586
This is just the cam. Also, if I do need the whole kit to do the upgrade, do I need to change my valve covers for the new rocker arms? I plan on doing this upgrade fairly soon so anyone that has done this to an LT4 please let me know...What other parts might be needed for an LT4?
By looking at the part #'s on gmparts-direct it seems all the other parts listed in the kit are already in the LT4 engine, other than the cam itself.
The difference in price is $170.00 for the cam compared to $475.00 for the whole kit.
Thanks,
Ted
[Modified by Hamert, 3:55 AM 1/8/2003]
Old Jan 8, 2003 | 03:32 AM
Zix's Avatar
Zix
Default Re: LT4/Hotcam question (Hamert)
You only need the cam, not the kit.
Old Jan 8, 2003 | 03:59 AM
Hamert's Avatar
Hamert
Default Re: LT4/Hotcam question (Zix)
That's what I thought, for $200 it totally sems worth it, for $500, have to think about it....
Old Jan 8, 2003 | 07:46 AM
GS345's Avatar
GS345
St. Jude Donor '11
I would replace the springs while at it too......only about $30.00.
jeff
Old Jan 8, 2003 | 08:44 AM
Goody's Avatar
Goody
Default Re: LT4/Hotcam question (GS345)
:iagree: Just order the cam and springs from Jeff Kopp and you are there. But, you'll need an intake gasket kit, timing cover gasket kit and maybe the oil pan gasket. All that isn't too bad but needs to be figured if you are budget conscious.
Old Jan 8, 2003 | 08:50 AM
96GS#007's Avatar
96GS#007
jeff
:yesnod:
Old Jan 8, 2003 | 09:29 AM
Nathan Plemons's Avatar
Nathan Plemons
I would fully agree on changing the springs, but I wouldn't put the LT4 springs back on it. I would highly consider something better. Sure it will work but a lot of people have had issues with the long term durability of LT4 springs with that cam. I would spend a little more on the springs that way you only have to do it once.
Old Jan 9, 2003 | 12:27 AM
Zora's Avatar
Zora
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: LT4/Hotcam question (Nathan Plemons)
:iagree:
Old Jan 9, 2003 | 12:37 AM
Hamert's Avatar
Hamert
Default Re: LT4/Hotcam question (Zora)
Like what springs? Does GM make better springs than the ones that would come with the kit or do I need to get aftermarket springs? Also, I assume the optispark has to come out to change the cam. Does that have a seperate seal or is it part of the timing cover gasket set? One other thing, does the cam affect emissions? I will need to pass CT emissions with the car once they open the program back up.
Old Jan 9, 2003 | 02:24 AM
No Go's Avatar
No Go
Do a search...all questions will be answered!
Old Jan 9, 2003 | 08:53 AM
96GS#007's Avatar
96GS#007
:iagree: but I couldn't find any springs with locators (or springs that would fit the stock locators) that were drop ins. They all required machining of the cylinder head :(
At rpms above 6000, I don't like the idea of my springs doing the hula hoop around the valve guide boss.
If someone knows of and can pass along the specific info on a drop-in spring that uses a locator or fits the stock locator, and has a seat pressure of ~120# closed, I'm all ears. I've tried Isky, CompCams, Crane, and Engine Works to name a few.
Old Jan 9, 2003 | 09:01 AM
Nathan Plemons
There are better springs that will fit stock locators. I'm not 100% sure which ones but call up Total Engine Airflow and find out, 270-782-6397, ask for Brent.
Your opti will be fine, you will need to replace the seal from the opti to the timing cover, but the opti itself never comes apart. A cam will very much affect emissions but the hot cam is mild enough to still pass. In the LT4 you can probably pass with no other tuning, if not with a good solid custom tune you can probably pass with lower emissions then you did stock. :cheers:
Old Jan 9, 2003 | 09:16 AM
1996man's Avatar
1996man
how much hp will you be putting out at the rear wheel since you already have the LT4 to begin with? if it is a stock 300rwhp are you looking at like a 330-345 rwhp possibly? that would be some damn nice power! what are the other things in the LT4 conspericy theory? 52mm throttle body and LT1 head gaskets? If i remember correctly if you do the hotcam and these other two things that your LT4 will dyno close to 400 flywheel hp!
Old Jan 9, 2003 | 09:20 AM
Nathan Plemons
Default Re: LT4/Hotcam question (1996man)
If you get the cylinder heads ported the upper limit for the hot cam seems to be about 370 hp or so regardless of if it's an LT1/LT4. The cam is the limit, not the airflow of the motor.
On stock cylinder heads you'll probably see more peak power out of the hot cam on the LT4 than the LT1, but not a whole lot more. Oh and BTW the 52mm TB is a crock and I've got the dyno graphs to prove it.
Old Jan 9, 2003 | 09:35 AM
Springer's LT4's Avatar
Springer's LT4
Cruise-In III Veteran
I gained 30 HP doing the hot cam and some intake porting on my LT4. The car won't gain anything with a 52mm TB, not unless it's turning some very high RPM or is a stroker. I haven't heard anything with the LT1 head gaskets thou? I know the LT4 intake gaskets are restrictive.
Old Jan 9, 2003 | 09:38 AM
FELNGR8's Avatar
FELNGR8
It's a Crane cam. Check with Crane directly on what exactly you need to do for the upgrade. That's what my speed shop is doing for my car.
Old Jan 9, 2003 | 02:15 PM
all4c4lt4's Avatar
all4c4lt4
Default Re: LT4/Hotcam question (Springer's LT4)
I believe the newer LT4 gasket pn is 12367777. It fits better than the stock gasket, which covered part of the opening. The newer gasket fits without extending into the opening.
To LT4/Hotcam question (again)
Old Jan 9, 2003 | 02:16 PM
Hamert's Avatar
Hamert
Default Re: LT4/Hotcam question (94lt1torchred)
Is it possible to change the springs without pulling off the heads? I really didn't want to have to do that but then again, I'd hate to drop a valve into a cylinder. :eek:
Old Jan 9, 2003 | 02:36 PM
Springer's LT4
I believe it is with the correct tools... when I did my hot cam Norris was going to charge me 300 more to do the springs, thats certainly a lot less then it would cost to remove the heads... I would be worried about setting up the correct spring pressures thou if you did it on the car.
I didn't change my springs when I did the cam, but I also don't race the car more then once or twice a year and I didn't increase my rev limiter.
Old Jan 9, 2003 | 04:15 PM
96GS#007's Avatar
96GS#007
Go to this link and you can see my write-up and photo's from when I did mine a few months ago...
http://www.hashmarks.com/techtips/valve_springs.htm
:cheers:
[Modified by 96GS#007, 3:16 PM 1/9/2003]
