1992 automatic climate control issues
Old Oct 7, 2022 | 02:41 AM
ReasonableName's Avatar
ReasonableName
3rd Gear
Default 1992 automatic climate control issues
I've got a couple of issues with my 1992 corvette's A/C. For some reason it only blows cold on recycling mode and when I try to change to any other modes such as feet or face it starts to blow to what I can best describe as "luke warm" air. It also doesn't blow hot either as when I raise the temperature on the climate control, it doesn't get hotter. I suspect that it could be the blend door actuator that could be at fault as even the climate control module gives me fault codes for 01 and 02 which I found were described as a temp door circuit fault for both codes. I've seen what nightmare of a job changing the blend door actuator is and I'd rather have some certainty that it is the actuator before I start tearing apart the dash. I've flushed the heater core in an attempt to solve this issue but it changed nothing.
