TPI intake base porting
Old Oct 9, 2022 | 07:24 PM
the blur's Avatar
the blur
Default TPI intake base porting
Who does intake porting? I'm looking for a mild port job. Just to clean it up, and not make the walls too thin. Don't want to create vacuum leaks. Just a mild clean up port.
Old Oct 10, 2022 | 11:39 PM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
i havnt heard of anyone doing that as a service in a long time.
Old Oct 11, 2022 | 10:42 AM
yakmastermax's Avatar
yakmastermax
Bump for looking for someone who does base and plenum porting as well!
Old Oct 12, 2022 | 09:55 AM
2manyfuncars's Avatar
2manyfuncars
You can do it yourself if you are cautious and get a die grinder and some carbide Al bits, flap wheels and sanding rolls plus some dividers. Easier with an air die grinder that can control the speed if you use long shaft carbide bits to get deep in the manifold runners. You'll need it to get to the middle of the runners along with long sanding rolls. An extended nose die grinder helps too. Do some research first and understand what MCSA you are looking for. Keep a vacuum around to suck up all the aluminum chips and use a face mask to keep the particulate out of your body.
Not a lot of fun but you can do it if you have some patience.
Old Oct 12, 2022 | 04:33 PM
eutu1984's Avatar
eutu1984
2021 C4 of the Year - Modified Finalist
Try doing a search on YouTube, there used to be a guy that ported TPI stuff, not sure if heis still doing it.
Old Oct 12, 2022 | 04:39 PM
VikingTrad3r
Oil Producer
that was most likely darin dochtorman and he doesnt do it anymore
Old Oct 12, 2022 | 08:19 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
FFI does some AWESOME porting. They can set you up with a TPI so big, you can drive a truck through the tubes!
Old Oct 13, 2022 | 06:15 AM
Phobos84's Avatar
Phobos84
I 2nd porting it yourself. I've done several TPI intakes now. You'll need a set of long shank single flute burr's. Also Harbor freight sells this awesome sanding roll kit with a very long shank on the paper holder.. It works really well for reaching in there.
But if you don't have the time or the patience, then I believe Fasterproms is still doing intake porting. At least they show that they were porting customer intakes on there YouTube channel about a year ago. I would give them a call.
Old Oct 13, 2022 | 06:27 PM
GREGGPENN's Avatar
GREGGPENN
I agree. I used a combination of wire wheels, burrs, and flap sanding. I put them on a long extention (with a 1/4" shank receiver)...though my burr has it's own 6" shank. I didn't even use any air-powered tools - like a die grinder. I used a 2k rpm drill. Burnt the **** up by the time I was done, but that's OK. Can't say I ever want to port another intake though! LOL
Old Oct 13, 2022 | 06:45 PM
Phobos84's Avatar
Phobos84
If you feel that way about an intake then don't ever try porting cylinder heads. I have a ridiculous amount of time into porting the set on my engine now and I still didn't get them even. +/- 1cc from runner to runner is the best I could do. I eventually decided I wanted bigger valves anyway so I sent a set of heads to Total Engine Airflow to get CNC ported so the'll at least be even.
Also as far as tools go I found the Harbor Freight small straight die grinder works really well for porting anything aluminum. The thing was only $10 and worked great until I dropped it and it broke.
Old Oct 14, 2022 | 03:45 AM
GREGGPENN's Avatar
GREGGPENN
Copy that. I left that up to AFR. OTOH, I do have half a notion to go at the runners a bit more. Or...have them fully extrude honed....Or swap to an HSR.
Of course, I've had 10 yrs to "rest up"! LOL
To TPI intake base porting
