Dropping lines
Old Dec 3, 2022 | 04:12 PM
johnfin's Avatar
johnfin
Default Dropping lines
Any of you guys dropped the fuel lines? If so, whats the trick, ie remove the tank?
Old Dec 3, 2022 | 04:36 PM
dieselgeek's Avatar
dieselgeek
I just did lines on my 86, rear diff has to be dropped and tank has to come out.
Old Dec 3, 2022 | 06:46 PM
johnfin's Avatar
johnfin
My car is not a rusty crusty, only the front hood reinforcement has a bad spot which is bad because thats where the headlight bracket mounts to. I unbolted most of the fuel like support nuts without a problem. Not going to drop the rear diff, no way. Someone hit something on the passenger side front floor board where the metal piece is and cracked the fuel line. They sell new lines, I might just get one and cut it in half around where the door is and use a 45 degree union brass flare.
To Dropping lines
