hood scoop intercooler
Old Jan 18, 2023 | 11:24 PM
drive it's Avatar
drive it
Default hood scoop intercooler
So I have to fit an intercooler in to keep it smog legal with the procharger p600b. I've been going crazy trying to fit different intercoolers where the air filter was or in front of the radiator. A decent size intercooler is going to make it overheat. I'm down to thinking of mounting it on top of the super ram/ cut a hole in hood and put an air scoop over it (subaru successfully runs them there).Has anyone done this? Instead of two separate intercoolers in that position on the sides like the Callaway I'm thinking of one in the middle. The "Vader" style hood scoop looks pretty decent and it can be cut to flow air, but I don't know if its tall enough.
Thoughts? Ideas?
Old Jan 19, 2023 | 07:13 AM
bjankuski's Avatar
bjankuski
Why don't you just buy the intercooled system from Procharger? if need add a larger radiator.
Old Jan 19, 2023 | 07:20 AM
dizwiz24's Avatar
dizwiz24
procharger hasnt put any recent r&d into their c4 kit
the small restrictive intercooler in that kit costs 3 psi (its restrictive) and its benefit on lowering IAT’s is going to be less than a modern intercooler
Old Jan 19, 2023 | 09:16 AM
TorchLT4's Avatar
TorchLT4
Have you thought about something like this?
https://www.frozenboost.com/liquid-a...er-p-1006.html
Old Jan 19, 2023 | 10:16 AM
drcook's Avatar
drcook
Finalist 2020 C4 of the Year - Modified
Look at this thread, start at post 20. The forum member that did that is still active on the forum
https://www.corvetteforum.com/forums...tercooler.html
Old Jan 19, 2023 | 02:51 PM
MrBigDee's Avatar
MrBigDee
What about methanol / water injection?
I have an Aquamist injection with a P600b supercharger and the air cooling works really well. I made the tank to replace the spare tire.
Easy to install
Old Jan 19, 2023 | 03:29 PM
drive it's Avatar
drive it
I was running the water injection with the paxton sn2000-part of the eo number. But with the procharger to remain smog legal (Kali) it has to have an intercooler.
Hmmm, the eo just says intercooler sooo,
https://www.cxracing.com/intercooler/IC0012-A
and
https://corvetteupgrade.com/product/...4r-hood-scoop/
I'll have to mount the IC a couple inches above the super ram plenum, intake and output to the rear, cut a tight fitting hole in the hood/ seal up around it with weatherstrip. Then put the scoop over that and open it up at the front to flow the most air. I've been measuring over under and around that car and this seems like the only viable option.
I already have the hood louvers so it'll end up looking like this.
https://www.ecklerscorvette.com/1984...M9x-UiyPY-yw8c
I can live with that, and it should work pretty well.
Old Jan 21, 2023 | 12:28 AM
Gale Banks 80''s Avatar
Gale Banks 80'
The Hood picture probably will have very i;little air flow coming in the front. The holes are probably more for looks than anything else. The rear of the Hood being up near the Windsheild should get some Air Flow though and You should plan on the Air movement coming from that direction. I wouldn't be surprised if the front scoops don't have air going backwards and out the scoops at certain speeds.
Old Jan 21, 2023 | 12:59 AM
drive it's Avatar
drive it
I was definitely planning on opening up the nose as much as possible. It was after looking closely at the twin turbo calloway hood intake from inside hood pics that I came up with this idea.
Old Jan 26, 2023 | 02:27 PM
85WHITEZ51's Avatar
85WHITEZ51
Have you thought about a liquid cooled intercooler option? You'll need to install a small radiator to cool the liquid that goes through it but they are pretty effective. It's what my Roush and Hellcat use to cool the air charges.
I don't know if they are still being made but you could mount the liquid radiator behind the license plate and install one of those ram air charger in the filler panel to get it airflow. This shouldn't impact the cooling system airflow but may help solve your problems. You'd have to trim the honeycomb structure for the bumper impact absorber but their should be enough space for a small radiator there.
Just trying to throw out some ideas for you. Not sure on actual feasibility, but logically it seems like it should work.
Picture of what I'm talking about below.
Old Jan 26, 2023 | 04:02 PM
JoBy's Avatar
JoBy
Some pictures I downloaded many years ago, so I don't know anything about the Corvette.
Old Jan 26, 2023 | 05:12 PM
drcook's Avatar
drcook
Just as an FYI, back in 1984/85 Ford used a hood scooped horizontal intercooler for the turbocharged Mustang SVO. So it does work to get air off the hood and push it through.
Depending on the size and position of a horizontal intercooler, there are sealing gaskets still available and could possibly be adapted, even if you had to run 2 side by side and a piece of flat stock down the middle of the IC to make a sealing surface (that is if a person uses an IC that is bigger than these gaskets.
https://lmr.com/item/LRS-16884/1984-...r-To-Hood-Seal
Old Jan 26, 2023 | 07:38 PM
drive it's Avatar
drive it
I had looked at air to water, however the carb eo specifically states air to air.
Old Jan 26, 2023 | 07:40 PM
drive it's Avatar
drive it
Thanks for those pics! I could totally live with that scoop or similar. I figure if it's functional then it's not rice lol.
Old Sep 1, 2023 | 10:02 PM
drive it's Avatar
drive it
Well, here's what I have-I still need to finish up the scoop-some sanding and bolt it down. Then I'll take it back off for paint matching. I think the intercooler will get fed plenty of air. And the radiator will also get plenty of air.
Old Sep 2, 2023 | 01:02 AM
MrBigDee's Avatar
MrBigDee
Nice!
It is interesting to know how much the intake temperature drops at full throttle.
For me, the temperature drops with methanol at 50% full throttle.
Old Sep 2, 2023 | 08:15 AM
htrdbmr's Avatar
htrdbmr
Is there a reason you can't run meth as well as an i/c?
To hood scoop intercooler
Old Sep 2, 2023 | 01:46 PM
drive it's Avatar
drive it
Sure, quite a few folk have. However I already sold my complete water/meth injection kit with the Paxton SN2000 that I had on there previously-it would be even tighter fitting everything now with the IC and the Kali EO for the Procharger lists an IC, not the water/meth injection. So I'll tune for the IC and make it work.
Old Sep 13, 2023 | 03:18 PM
drive it's Avatar
drive it
Originally Posted by MrBigDee
Nice!
I've been looking into upgrading my P600 impeller. It looks like a how to rebuild on youtube was you? You used the upgraded impeller? Do you happen to have before and after boost? Thanks! I'm still on part throttle VE tuning so don't have a current max boost number with the stock impellor and the new 401 engine.
Old Sep 13, 2023 | 04:38 PM
turbols3c4's Avatar
turbols3c4
Tilted rad with a splitter, duct and waterfall vent should work well. I’ll have pics of it together in a few weeks
