skipping LT1
Old Jan 12, 2003 | 05:04 PM
NickC493's Avatar
NickC493
Default skipping LT1
I have a 93 LT1 that has developed a skip. It skips while going down the road. This problem is really starting to drive me nuts, but I can't find anyone around here with service manuels that can tell me where to start looking for the problem, so if any of you have ever had this problem please let me know how you cured it .
thanks :thumbs:
Old Jan 12, 2003 | 06:09 PM
STL94LT1's Avatar
STL94LT1
Default Re: skipping LT1 (NickC493)
It sounds like symptoms of the opti spark going bad.
Old Jan 12, 2003 | 08:18 PM
DRAGRCR1005's Avatar
DRAGRCR1005
what would make you believe it has a trans problem? sounds from the description it is misssing? :iagree:
Old Jan 12, 2003 | 08:53 PM
ShawnZR-1's Avatar
ShawnZR-1
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'05-'06-'10-'11-'12
It could just need a tune up. When were the plugs and wires changed last? Mine started to develop a miss and I figured I'd spend $60 on plugs and wires first to see if that fixed it, and it did! That was 15000 miles ago, so I don't think the opti is bad.
Old Jan 12, 2003 | 11:43 PM
NickC493's Avatar
NickC493
Default Re: skipping LT1 (92Shawnster)
I guess I should have mentioned that I had already changed the plugs and wires, and it didnt fix the problem. I even double checked to make sure that hte wires were making contact.
Old Jan 13, 2003 | 09:36 AM
PTz-92-LT1's Avatar
PTz-92-LT1
Opti-Crap! :smash: :smash: :smash:
Old Jan 13, 2003 | 10:28 AM
ShawnZR-1's Avatar
ShawnZR-1
Welp, in that case, your Opti is seriously suspect. Just for grins, check your coil connections and opti harness plugs, but I think you're in for an opti/water pump replacement. :yesnod:
Old Jan 13, 2003 | 08:18 PM
NickC493's Avatar
NickC493
92Shawnster are there any good Corvette mechanics around norcross?I have yet to ffind a good one in the Athens area.
To skipping LT1
