Pulled Code but SES not blinking
Old Jan 12, 2003 | 06:20 PM
MGNETIC's Avatar
MGNETIC
Default Pulled Code but SES not blinking
Here I go again, maybe this is related to the other thread about a new drive train noise. I got the SES light. Last time all we did was make sure the gas cap was tight and it went away. It is staying on now so I did a search to find out how to read the codes. I have a 96 LT4 for reference. I put a paperclip in the upper to right slots and turned on the key but not starting it. The SES light does not blink at all. Do I need to jumper some other locations for this car?
Old Jan 12, 2003 | 06:57 PM
chucks88's Avatar
chucks88
Default Re: Pulled Code but SES not blinking (1stC5)
I bevieve you have to connect the other end to the terminal to the emidiate left of it also.
Old Jan 12, 2003 | 07:11 PM
MGNETIC's Avatar
MGNETIC
Default Re: Pulled Code but SES not blinking (chucks88)
Yep, did that but I was not clear about my explanation.
Old Jan 12, 2003 | 07:15 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
You have a 96, OBDII system. You need a scanner to pull codes!
Old Jan 12, 2003 | 07:57 PM
MGNETIC's Avatar
MGNETIC
Default Re: Pulled Code but SES not blinking (PeteL)
Thanks, I guess I will take it to the Mr. Goodwrench, if the SES light does not go out soon. I am learning more about Corvettes every day and appreciate the help I get from the Forum.
To Pulled Code but SES not blinking
