Help with valve lash!
Old Jan 13, 2003 | 02:38 PM
ROME's Avatar
ROME
Default Help with valve lash!
I'm adjusting my valves and ran into a situation with one of the exhaust valves. I'm doing my standard 1/2 turn to set, but one of my exhaust valves doesn't want to tighten that far :confused:
What do you do if you can't even get 1/2 turn while setting a valve (i'm getting maybe 1.4 turn)? Is this a sign that something might be wrong, or should I simply tighten it down 1/4 (as ffar as it will go) and go to the next valve?
Old Jan 13, 2003 | 03:08 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: Help with valve lash! (ROME)
Did you unscrew the set screw out of the rocker nut?
Old Jan 13, 2003 | 03:57 PM
ROME's Avatar
ROME
Default Re: Help with valve lash! (Vette92)
That was the problem :thumbs:
Can you tell this is the first time I've done this in ten years? :lol:
Old Jan 13, 2003 | 05:53 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
:cheers:
Old Jan 13, 2003 | 09:04 PM
cprgmr's Avatar
cprgmr
Interesting that the general consensus is 1/2 turn past zero lash for rocker adjustment. I was doing a bit of perusing in my service manual and it calls for one full turn past zero lash. Hmmmm.....
Old Jan 13, 2003 | 10:36 PM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: Help with valve lash! (cprgmr)
i usually go 1/4 turn past preload for more rpm on a hydylic cam the tighter you make it the lower the rpms will come down :cheers:
To Help with valve lash!
