O ring tear
Old Mar 17, 2023 | 08:34 PM
johnfin's Avatar
johnfin
Default O ring tear
Someone posted a thread not too long ago about fuel
inlet orings. I had to remove my new oring install because i had to run the lines thru the ac bracket. I noticed that the smaller oring had a tear and i installed it with silicone lube. This time i installed them u
sing
motor oil. Why are they tearing.
Old Mar 17, 2023 | 10:12 PM
turbo6inky's Avatar
turbo6inky
inlet orings. I had to remove my new oring install because i had to run the lines thru the ac bracket. I noticed that the smaller oring had a tear and i installed it with silicone lube. This time i installed them using
You may have a burr inside the fitting, or you don't have the fitting seated fully before you're tightening the line nut down and it's getting pinched.
BTDT. I buy O-rings in bulk now.
Old Mar 18, 2023 | 04:13 AM
'78CorvetteS.A.'s Avatar
'78CorvetteS.A.
Old GM garage trick for o-ring lube....with your finger tips, wipe on a nice light layer of Dawn dish soap (like one drop on index finger)! Won't harm the rubber or anything else. Everyone at the dealership I worked at, had practiced using it for decades....never a single issue! But the above advice is spot on, have the line seated with pressure from your 'off' hand before tightening the nut👍
To O ring tear
