CAGS disable
Old Jan 16, 2003 | 07:01 AM
Ernest's Avatar
Ernest
Default CAGS disable
I want to disable the 1-4 shift.Anything I should do other than disconnect the cable?Do any codes register? :confused:
Old Jan 16, 2003 | 08:15 AM
Nathan Plemons's Avatar
Nathan Plemons
Default Re: CAGS disable (Ernest)
Depends on the year of the car. I know in 92 you can just unplug it.
Old Jan 16, 2003 | 08:19 AM
The Dingo's Avatar
The Dingo
CI 6-7-8-9-10 Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-‘17, '22
Default Re: CAGS disable (Nathan Plemons)
FWIW, the OBDII C4's need a specific plug to be used when you disconnect the CAGS plug to prevent a code. I think it is 95 and later that this applies to. Anyone care to verify?
Old Jan 16, 2003 | 09:14 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
I disabled my CAGS by pulling fuse #28. It works fine, the only downside being that it also disabled my backup lights. Speaking only for myself, I'll make that trade-off anyday.
Larry
'96LT4coupe
:seeya
Old Jan 16, 2003 | 09:19 PM
StealDads67's Avatar
StealDads67
Default Re: CAGS disable (rocco16)
.... Whyd don tyou just get the eliminator for like $20 and have our backup lights? Its much easier that way... and safer and smarter....
Old Jan 16, 2003 | 09:24 PM
don hall's Avatar
don hall
It would help to know the year of your vette. You might be able to just unplug the relay on the passenger fender well. And yes, you will show a DTC 27.
Old Jan 16, 2003 | 10:10 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
If you still have the 92 car, all you have to do is unplug the cags connector on the drivers side of the Zf trans. Some kind of seal would be a good idea to prevent destruction of the connectors by the elements.
No code will set on a 92.
To CAGS disable
