Help!!
Old May 21, 2023 | 04:46 PM
delseavette's Avatar
delseavette
Cruising
Default Help!!
My seat belt will not pull out,i have spent hours trying to get it out,only comes out a few clicks once in a while. i have push the cinch button about 972 times nothing!! i
live in a small town and the police will pull me over for this,so I can not drive my vette!! any ideas,help would be great!!!!!thanks
Old May 21, 2023 | 06:58 PM
Topduarte's Avatar
Topduarte
Patience. Jiggle it and see if it comes loose.
Old May 21, 2023 | 06:59 PM
s carter's Avatar
s carter
Odds are the Pendulum weight is stuck. First try sliding seat forward so you can get a to the retracter, give it a hit with your first or a mallet while giving a little push back on belt or winder.
if this doesn't work try giving a 3/8 extension as a punch give the mount bolt a wrap or 2 if this fails your pulling the Adjuster
Also the cinch button Locks the belt but should allow the belt to function normally once retracted
Old May 21, 2023 | 07:11 PM
delseavette
Cruising
thanks i'll try them tomorrow!! thanks agian
Old May 21, 2023 | 11:32 PM
Patsgarage's Avatar
Patsgarage
Worst case try these guys for a rebuild of the mechanism.
https://www.safetyrestore.com/seat-b...lt-repair.html
To Help!!
