Replace Knock Sensor just because removed?
Old Jun 4, 2023 | 09:57 AM
dburgjohn's Avatar
dburgjohn
Default Replace Knock Sensor just because removed?
I pulled knock sensors in order to drain coolant. They had not malfunction before and I don’t know if I can put them back or if they should be replaced with new ones simply because they were removed. Also, does anyone know the torque specifications for a knock sensor? They are a pain for big guy to get to, and I don’t want to do this again.
Old Jun 4, 2023 | 10:04 AM
rremesal's Avatar
rremesal
Absolutely! No sense putting old stuff back in, especially when connections may be rusted, plastics brittle, and now possibly contaminated after removal.
Old Jun 4, 2023 | 02:07 PM
don hall's Avatar
don hall
Torque for knock sensor -
Old Jun 6, 2023 | 05:04 PM
dburgjohn's Avatar
dburgjohn
bought some AC Delco knock sensors. Trying not to polish them before installing them.
That is a bear of a spot to use a torque wrench
Old Jun 7, 2023 | 10:56 AM
eutu1984's Avatar
eutu1984
2021 C4 of the Year - Modified Finalist
I believe 14 ft lbs for knock sensors according to my 90 FSM
I recently refreshed my 383 and put in a new knock sensor and had all sorts of false knock
ended up going back to the old one
on another occasion a brand new knock sensor died in 10 minutes
make sure you get AC Delco knock sensor your chances are better than one of the cheap ones.
Old Jun 8, 2023 | 07:34 PM
detroitrust's Avatar
detroitrust
The ones you pulled should have a good amount of crud on the tips. I have replace a ton of stuff on my 95, knocks included. Working on my 93 and prices have certainly gone up. Thankful suppliers are still selling oem or better stuff.
Old Jun 16, 2023 | 02:59 PM
dburgjohn's Avatar
dburgjohn
you need three arms to get a torque wrench, extension, swivel and socket on those sensors
Old Jun 16, 2023 | 04:16 PM
detroitrust
Did you take off the shields? The only other thing in the way would be the oil filter. Should be clear. Mine can off with no effort.
Old Jun 17, 2023 | 01:02 PM
dburgjohn's Avatar
dburgjohn
I did but the exhaust pipe makes you need a flex joint
Old Jun 17, 2023 | 08:02 PM
SJW's Avatar
SJW
I've had the originals out of mine several times, and have always spun them right back in after coolant drain was completed. Never saw a good reason to replace them. YMMV.
Live well,
SJW
To Replace Knock Sensor just because removed?
