4l60e swap
Old Jun 9, 2023 | 08:10 AM
jmalez's Avatar
jmalez
Default 4l60e swap
can i take any 4l60e transmission and just replace the tail shaft housing ( if i take a 1995 firebird 4l60e transmission and change the tail-shaft housing and put it into a 1995 corvette , will it fit ?)
Old Jun 9, 2023 | 01:45 PM
383vett's Avatar
383vett
Use a cutoff wheel and cut 5/8" off the end of the tailshaft. Then it will work.
Old Jun 9, 2023 | 07:14 PM
drive it's Avatar
drive it
You need a stand alone controller to run it. Also if you use the VSS on the 4L60E with the corvette tail housing you need to grind out clearance on the housing for the pickup ring.
Old Jun 10, 2023 | 11:24 AM
383vett's Avatar
383vett
The op is putting a 1995 firebird 4l60e tranny into a 1995 Corvette
Old Jun 10, 2023 | 12:07 PM
jmalez's Avatar
jmalez
I used the firebird as an example, I am purchasing a rebuilt transmission from dannys transmissions, they advised there should be no problems with the swap, I was just looking for information if any 2wd 4l60e would be able to be installed in a 95 corvette or if there is something special outside the tail shaft i should be thinking of, that's it
To 4l60e swap
