85 oil cooler delete
Old Jun 15, 2023 | 09:15 PM
sturmmorser2000's Avatar
sturmmorser2000
Default 85 oil cooler delete
I ve removed the oil cooler unit from my 85 i want to just use an oil filter Is that all i have to remove to use the oil filter?
Old Jun 17, 2023 | 12:00 AM
jv9999's Avatar
jv9999
You'll need a regular small block oil filter adapter like this: https://www.summitracing.com/parts/s...8-900/make/gmc
Old Jun 17, 2023 | 12:41 AM
sturmmorser2000
What i got on there looks like that . It has the spring valve on it. I tried screwing my old oil filter onto it and it seemed to be ok.
Old Jun 17, 2023 | 08:45 AM
RF1's Avatar
RF1
You are good to go.
Old Jun 17, 2023 | 09:42 AM
WVZR-1's Avatar
WVZR-1
OP - what have you done with the original plumbing for the 'hot water'? Just the filter adapter mentioned ain't 'JOB DONE'!
Old Jun 17, 2023 | 07:39 PM
sturmmorser2000
I removed the lines ,capped the block,and ran a hose from the water pump to the heater core
To 85 oil cooler delete
