From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
Alternator volts output
A friend of mine is concerned about the volts reading on his 1995 Corvette. Mine only varies a few tenths of a volt from 14.4v but his jumps around between 13.8v to 15.0v. The Helms manual says 13-18volts is normal which is not a lot of help. That seems very high to me.
What is everyone seeing on their digitial read outs?
Not enough info on when your friend is seeing a voltage sag, but you'll definitely see minor variations when the fans kick on, when the A/C clutch engages, AIR pump, etc. Once eveything has settled out I normally see 14.4-14.7 on my gauge.
But any reading over 12.7 I'd think is OK... But I'd keep an eye on it. You should normally see voltage readings over 13 with a decent battery.
With the engine idling and a heavy electrical load, you can see the voltage drop to 12, but underway the voltage will be around 14.3 volts engine cold and as the alternator warms up the voltage will drop to 13.3 or so. The alternator cannot deliver full current rating at idle speed and is why the voltage to sag at stoplights etc. Its nothing to be concerned about because you spend little time idling.
[Modified by Mez, 10:17 PM 1/20/2003]
Yours sounds about right; your freind has IMO something going on which would be of concern to me. 15VDC just sounds high; high 14s might be ok with some RPMs and heavy charging, but should taper off as battery approaches full charge. Might try starting by checking accuracy of digital guage with a seperate DVM if one is available. Assuming the guage is accurate, the next step would be to check connections and make sure they are tight and not corroded. Use baking soda to clean battery terminals. I would say that any voltage above 16VDC with a known good battery would indicate a defective voltage regulator (alternator). Voltage > 15 - 16 VDC will kill your battery as in cooking it. There is a thread on rebuilding your alternator - very good post.
For what it is worth, when mine was kicking up above 14.4 - 15, the alternator was dying a slow death. Over time it was closer to 15 and the dash and headlights started flashing at idle, then the starter would turn very slow. Took the alternator in for a test and it was beyond bad.
I would get the alternator tested.
:iagree: Mine was jumping around too...pulsing dash lights made my interior look like a disco.... put in a new HD (140 amp) alternator...problem solved.. 14.3 steady.. good luck
