PKE problem
Old Aug 24, 2023 | 04:02 PM
Tomkom's Avatar
Tomkom
1st Gear
Default PKE problem
Engine will not crank. Constant clicking right side of dash.
Old Aug 24, 2023 | 06:05 PM
s carter's Avatar
s carter
Let's start basic, if you know the battery is good. Lock the and walk away for a few minutes let the car reset, using the key unlock and try to start. If it starts take it up a notch close the door walk away see if it does the normal lock down.
Old Aug 30, 2023 | 09:11 PM
pcolt94's Avatar
pcolt94
If the security light is not on steady, then it's not a PKE problem. It takes 3 to 5 minutes for VATS to reset and key has to be in off position.
Check the battery voltage with a meter as well as the battery connections.
There is clicking from the right side as I have heard it also but I would not focus on that for a fix.
Don't forget the starter could be bad.
To PKE problem
