Engine swap for 1985 c4.
Old Sep 25, 2023 | 02:35 PM
S Cas's Avatar
S Cas
2nd Gear
Default Engine swap for 1985 c4.
Had bought the car about a year and a half ago, fixing issues with cooling and electrical, even bought a new and bigger radiator for the car, just for it to still overheat, instead of flushing more money into this car I think it's better to just look for a new engine, preferably an upgrade with more power, what recommendations are there for me and what transmission will work best?
If I can keep the original transmission that would be great.
Old Sep 25, 2023 | 08:16 PM
Phobos84's Avatar
Phobos84
Do a search. This has come up over and over on this forum.
Everyone has there opinions. I'm an LS or nothing kind of guy. I wouldn't touch a small block at this point in my life. I would swap the motor and the trans and run the whole thing with a Holley ECU. It's a lot of work but it's well worth it. If you play your cards right you can get it done pretty cheap too. I made a video about a budget LS swap on my YouTube channel years ago. (So did a lot of other people). So you could look there for a lot of options and really good info.
Old Sep 26, 2023 | 03:04 PM
64Scout's Avatar
64Scout
Have you checked your thermostat? Water pump?
Any SBC will bolt in and work, LT1 will take some more work. Yes you can LS swap your car and keep the original transmission. that will be a lot of money nd may not be worth it, depending on what you do with the car.
Old Sep 27, 2023 | 05:21 PM
sheriffjim's Avatar
sheriffjim
Personally I would but a 383 in it. I'm a big fan of rebuilding the original engine and making it a 383 stroker, and I hope to do that myself eventually. I've heard lots about the zz4 and zz6 crate engines from Chevrolet, although I have no personal experience with them. I would do a search and see if those might be a good option for you.
Old Sep 27, 2023 | 07:08 PM
Phobos84's Avatar
Phobos84
I used to love the 383. I loved the fact that I could go to the junk yard and pull a crank out of a trashed truck with a 400 small block and after spending $50-75 at the machine shop I could put it in a 350 (along with the 400 balancer and flexplate) to make more power. But those days are long gone. All those older 400's have dried up. I think that's why now I got into LS engines. For well under $1000 I can have 400 whp and a better transmission. I never made that kind of power with my 383. But I'm sure it was a lot more than the stock 350 could offer and for very little money.
To Engine swap for 1985 c4.
