Differential ratio
Old Oct 17, 2023 | 06:55 AM
dentalfloss's Avatar
dentalfloss
Default Differential ratio
Hello. I posted a thread on this earlier and had trouble, sorry.
In the process of finding a Dana 36 with 307 ratio for sale I found many for sale that did not list the ratio and upon asking them they had no idea. When selling a diffferential knowing the ratio is important to the sale. I compiled what I know and learned about figuring out different ways on a c4 Corvette.
1. The C4 rear axle ratio RPO numbers like this:
RPO Rear End Gear Ration
GM1 2.59
GU2 2.73
GW4 3.31
G44 307
2. Read ring gear
If you can look at the large ring gear there you will see 2 numbers.
Example: 43-14 , you divide the smaller number into the larger number and you get 307 ration and so on.
3. Etching from factory on carrier
On most C4 carrier's I find there will be etching on the bottom showing date and ratio.
you will have to clean and scrub usually to read it.
4. Using the rotating method.
Not so accurate but close enough is this method. Mark your drive shaft or drive shaft yoke with tape or a marker, then mark your tire/brake/rotor/half shaft yoke depending on installed or not. Rotate the above 1 revolution 360* while counting how many times your drive shaft yoke turns. for example if your drive yoke turns a tiny bit over 3 turns you have 307 ratio.
Old Oct 17, 2023 | 07:06 AM
*89x2*'s Avatar
*89x2*
From: ...tearing up the highways, one state at a time™®©
Some good info if one could get past the numerous typographical errors
GH0, for example, is 3.54:1
Clean up your copy and you will be helping.
Old Oct 17, 2023 | 07:25 AM
WVZR-1's Avatar
WVZR-1
Why didn't you just 'clean-up' your other post/thread?
https://www.corvetteforum.com/forums...xle-ratio.html
This is quite a mess! I didn't even check this .pdf!
Old Oct 17, 2023 | 08:11 AM
dentalfloss
Don't have a heart attack on me please.
Old Oct 17, 2023 | 08:13 AM
dentalfloss
Chill, life is too short
Old Oct 17, 2023 | 08:16 AM
dentalfloss
Thank you. I did edit the GHO and cleaned up the copy with the help of my girlfriend
Thank you
Old Oct 17, 2023 | 08:26 AM
WVZR-1's Avatar
WVZR-1
Thank you
Bothers me NOT but I don't get it. In recent posts I've clarified for you every question regarding rear axle ratios that you asked. You excluded (in this rendition) some of the more relevant information I've supplied you.
Now you've mentioned 'fixing' and you actually haven't GH -zero- is 3.54 NOT GH -oh- !
If I was bothered I'd just post corrections but I'll 'delete' my posts and let you have at it maybe!
Old Oct 17, 2023 | 08:30 AM
*89x2*'s Avatar
*89x2*
It’s GH0
…not GHO
Old Oct 17, 2023 | 09:49 AM
dentalfloss
Default some more stuff
GM1 2.59
GU2 2.73
GW4 3.31
G44 307
2. Read ring gear
I'm adding a ring gear picture, Etching picture and video for roatating method.
Old Oct 17, 2023 | 12:30 PM
bjankuski's Avatar
bjankuski
Thanks for the info, never new they had a Dana 36 with a 3.54 ratio.
Learn something new every day!
Old Oct 17, 2023 | 12:44 PM
WVZR-1's Avatar
WVZR-1
There NEVER was a D36 3.54 from GM - NEVER!!!
Old Oct 17, 2023 | 01:48 PM
bjankuski's Avatar
bjankuski
OK, that is what I thought (Dana 44 had a 3.54) but in this post it was not disputed so I thought maybe I was uninformed,
Old Oct 17, 2023 | 08:49 PM
dentalfloss
I posted this thread to try and help members in finding Dana 36 differential ratios. I have recieved help above in my errors from members more in the know and have edited my post as I go along and any helping comments are welcome. If this helps only one member is good enough for me. Thanks for listening
To Differential ratio
