Greetings!
Old Nov 25, 2023 | 07:41 PM
4to1ratio@gmail.com's Avatar
4to1ratio@gmail.com
6th Gear
Default Greetings!
I just bought my wife an 84 corvette just like her Dad had when she was a kid. Same color scheme as well. Low miles. Mint condition. Wondering though about right headlight. It opens and closes no problem. The light motor grinding awful after closing. Any thoughts?
Old Nov 25, 2023 | 08:57 PM
Moved to C4 Tech.
Old Nov 25, 2023 | 10:37 PM
kkupec02's Avatar
kkupec02
welcome
Old Nov 26, 2023 | 08:12 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Welcome, lot of information here, good luck!
Old Nov 26, 2023 | 09:58 AM
Vets-Vet's Avatar
Vets-Vet
Probably the plastic headlight gears, if you remove the motor do yourself a favor and remove the entire assembly, I recommend NOT trying to remove just the motor from the car. Also, the metal tabs go between the 2 rubber grommets so they can act as a cushion for the headlight hitting the stops in both directions. 84 headlight motors are probably 2 wire as later motors are 3 wire in case you replace check which one you have.
Old Nov 26, 2023 | 01:14 PM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
Good Luck
Old Dec 1, 2023 | 12:28 PM
4to1ratio@gmail.com
6th Gear
Originally Posted by Gixxerman
Good Luck
Thanks!
Old Dec 1, 2023 | 12:34 PM
SloJo's Avatar
SloJo
There are many videos on YouTube on how to repair the motor gears and many other problems with the C4.
Old Dec 1, 2023 | 01:18 PM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
sounds like the pellets.
Old Dec 1, 2023 | 02:36 PM
Vets-Vet's Avatar
Vets-Vet
I think 88 was the fist year for pellets.
To Greetings!
