95 Steering pump replace: Need tips and recommendations
Old Mar 14, 2024 | 06:32 PM
MarkGM's Avatar
MarkGM
Default Help, no power steering
Replaced the pump today and also replaced the 2" hose that runs from the tube on the bottom of the pump to the reservoir. It was the source of the leak.
Tires up in air, filled reservoir and turned wheel back and forth 20 times. Wheels turmed easily and reservoir was still full. Repeated with same result.
Put the car on the ground and i have no power steering. No leaks, newer belt, and I did take the plug that comes on the new pumps tube off. And took off the plastic fitting out of the high pressure side too.
What gives? Bad pump? Air pocket? BTW no leaks. If the high pressure hose was bad wouldn't I have fluid spilling quickly?
Old Mar 15, 2024 | 10:36 PM
MarkGM's Avatar
MarkGM
To the top
Old Mar 16, 2024 | 02:11 PM
ChumpVette's Avatar
ChumpVette
Have you checked for a possible obstruction in the rack?
Old Mar 16, 2024 | 04:52 PM
MarkGM's Avatar
MarkGM
No, but it occurred to me that one or more of the hoses may have collapsed inside and the layers are now blocking flow.
Rack was smooth before the new pump but guess it could have gotten clogged too. How would I check that?
Right now i am pulling the pressure line from the pump to confirm that a pressure valve is in the rebuilt pump. I've heard that has happened before. I should be able to feel the spring by using a small screwdriver in the hole. But then I have to get that danged pressure line nut back in straight. That's a struggle.
Either way, I'm going to try another pump. If that doesn't work I'll have a shop replace the hoses. They look too hard to get to laying under the car. And i wouldn't know which ones are blocked.
Old Mar 17, 2024 | 06:27 AM
Whaleman's Avatar
Whaleman
What brand pump did you end up buying? Dan
Old Mar 18, 2024 | 09:14 AM
MarkGM's Avatar
MarkGM
Off-brand rebuilt. Serves me right. Tomorrow I'm going to reinstall the stock pump. If the system works again, even with some groans, I'll know I received a bad pump. If so, I'll look for a brand new pump which are sometimes available.
If not, I think I can assume I have a collapsed hose or two.
Old Mar 18, 2024 | 09:51 AM
Whaleman's Avatar
Whaleman
Did you consider having Turn One rebuild yours? Or was the cost just too high. Dan
Old Mar 18, 2024 | 09:53 AM
ChumpVette's Avatar
ChumpVette
Just send your original to Turnone. Already spent more time on this than was needed.and now you are doing the job twice.
Old Mar 18, 2024 | 10:48 AM
MarkGM's Avatar
MarkGM
You and ChumpVette are both right. Cost is not an issue but, thIs is my daily driver so it needs to be running. Should have taken it to the shop but I like the hands-on wrenching.
My backup, a 66 Corvair w/ a mid-engine 327 is also on stands waiting for me to finish the new fuel, brake and clutch lines.
I'll update the post after tomorrow.
Old Mar 18, 2024 | 09:25 PM
Whaleman's Avatar
Whaleman
Turn One is expensive. A rebuild starts at $200.00 and can go up. New ones on Ebay go for $70.00 free shipping. Dan
Old Mar 18, 2024 | 09:27 PM
ChumpVette's Avatar
ChumpVette
And, I’m sure that value difference drops when you have to do the job twice.
Old Mar 18, 2024 | 09:44 PM
MarkGM's Avatar
MarkGM
Yeah, the PITA price is high.
Old Mar 19, 2024 | 09:23 AM
  #33
Whaleman's Avatar
Whaleman
I understand your thinking Mark. A rebuilt master cylinder or opti is taking a chance. But, a power steering pump is so simple with only a few parts to be replaced to put in new condition that it should not be such a chance. Dan
Old Mar 19, 2024 | 11:36 PM
  #34
MarkGM's Avatar
MarkGM
Default Now that's better!
Pulled the rebuilt pump and installed one from another vendor. I need this car daily so waiting on a new pump is a problem. Besides, new pumps are scarce.
The rebuilt I just installed works great. I knew there was a difference as soon as I turned the car on and started turning the wheel. My core will go to Turn One and become my backup.
Thanks for the help and support.
