Alternator swap
Old Jan 24, 2003 | 10:53 PM
MagikDraggin's Avatar
MagikDraggin
Cruise-In IV Veteran
Cruise-In V Veteran
Default Alternator swap
I have this annoying "sys" that starts flashing 3 times every 20 seconds when I have the stereo amp (250w), headlights and heater fan running at the same time. I'm assuming I am exceeding the output of the factory alternator, (or it's just getting tired).
Is swapping out the alternator for one with increased output a simple R & R procedure? Any pitfalls I should be aware of...voltage regulator, wiring, etc?
Karl
Old Jan 24, 2003 | 11:06 PM
Bob86ZZ4's Avatar
Bob86ZZ4
Default Re: Alternator swap (MagikDraggin)
I have a huge stereo with two big Alpine amps. I went to a well known local rebuilder shop and talked to the guy there. He sold me a rebuilt that he said he built with the best parts, I can't remember what he said it would put out. But now when I crank it up with the lights on they don't flicker with the bass notes like before. The alternators in our cars are kind of known to be a weak link. It's nice that they are so easy to change. Good Luck.
Old Jan 24, 2003 | 11:38 PM
MagikDraggin
Cruise-In V Veteran
Default Re: Alternator swap (Bob86ZZ4)
Thanks for the response, Bob. I realize I ask some pretty dumb questions here, and many probably feel it is beneath them to bother with an answer.
I look at it this way. If I was an "expert" on everything, I wouldn't be asking. I hate surprises.
Thanks again.
Old Jan 25, 2003 | 08:33 AM
Tom Piper's Avatar
Tom Piper
Has anyone tried the super high output "Mean Green" alternators yet? http://www.mean-green.com/products/alternator.html
Tom Piper
Old Jan 26, 2003 | 09:32 PM
Bob86ZZ4's Avatar
Bob86ZZ4
Default Re: Alternator swap (Tom Piper)
Their web site makes them look like a pretty nice alternator, and starter too for that matter. Interesting that they don't really tell you where to go to get one. You have to contact them it looks like. I also couldn't find a price anywhere. That makes me think they might be rather pricey. But heh, if we were trying to save money we wouldn't be driving Vettes now would we?
Old Jan 27, 2003 | 07:31 AM
Tom Piper's Avatar
Tom Piper
I think you can buy them at JC Whitney.
Tom Piper
Old Jan 27, 2003 | 07:36 AM
gtsyellow's Avatar
gtsyellow
the other thing i found out is the local parts stores who rebuild them sometimes offer "good" rebuilds if you pay a little more. they can use better parts, higher output stuff etc...i've blown 4 alternators in a year..rpms and heavy loads kill the cheapies
Old Jan 27, 2003 | 07:39 AM
BBA's Avatar
BBA
Bob, I think you are confusing the topic, since the 96 already has an alternator that is known as being one of the best you can have, and the 86 has the biggest POS alternator ever made. Your experiences are not relevent to the 96 cars.
If you have an electrical problem with the 96, you just might have a bad alternator...which is uncommon for that model. Have it tested, and if you still need a higher capacity alternator, you will have to look into stereo shops for super high current models...they are out there, but they are very expensive.
Old Jan 27, 2003 | 10:21 AM
Bob86ZZ4's Avatar
Bob86ZZ4
Default Re: Alternator swap (BBA)
Sorry then. I didn't know they made a change for the '96's. Never mind above post from me, unless you have a '86 then regard it.
Old Jan 27, 2003 | 12:27 PM
BBA's Avatar
BBA
While we are on the topic Bob, I solved all my 87's alternator problems by switching to a '96 unit. I had to do some minor bracket clearancing, but other than that is was pretty much bolt in and go.
If you have any more problems, like low voltage at idle with AC/Fans/Stereo/Lights on, the 96 alternator will definitely solve it.
Old Jan 27, 2003 | 01:51 PM
Bob86ZZ4's Avatar
Bob86ZZ4
That's good to hear. Has this info been around on the Forum? I never have seen any posts about it but that doesn't mean it hasn't been posted. When (notice I said "when" not "if") my alternator goes out I will look into that '96 upgrade then. I wonder if it would work on my '87 Chevy van? I've only had to put a couple alternators in that.
Old Jan 27, 2003 | 05:14 PM
BBA's Avatar
BBA
I made a post here last summer with pictures and instructions.
I'm sure you can find it if you look.
To Alternator swap
