hvac vacuum sourse
Old Jan 20, 2024 | 01:32 PM
biker mike's Avatar
biker mike
Default hvac vacuum sourse
trying to fix my hvac system and i have no vacuum at the module, i'm pretty sure that vacuum comes off of the motor at the tee fitting that i replaced. my question is the does the hvac come off of the branch of the tee or the run or the through port?
Old Jan 20, 2024 | 03:58 PM
pcolt94's Avatar
pcolt94
What year car?
When you say module do you mean programmer?
Basically need to check hoses to the cruse servo, and brake pedal cut off hard line hose, and rubber hoses and look for a crack or break.
There should be vacuum at the T from the engine.
Old Jan 20, 2024 | 04:13 PM
ChumpVette's Avatar
ChumpVette
Vacuum source is the intake manifold. From there it going the wire harness and passes through the firewall at the center bulkhead. It has a connection underneath the passenger side of the dash and joins the AC vacuum harness.
Get a vacuum pump and connect at the fitting at the intake and see if you can hold vacuum. Work your way to the next connection point until you find your leak.
Old Jan 20, 2024 | 06:52 PM
biker mike's Avatar
biker mike
it turns out that the vacuum sourse for the hvac is on the branch of the tee the run connection ios for the cruze and vacuum canister
Old Jan 21, 2024 | 07:38 PM
dburgjohn's Avatar
dburgjohn
have you found the leak yet?
To hvac vacuum sourse
