Gonna upgrade injectors...any tips?
Old Jan 26, 2003 | 08:24 PM
95AquaC4's Avatar
95AquaC4
Default Gonna upgrade injectors...any tips?
Going with the Ford 28 lbs/hr. Is there anything else I will need? Any removal/installation tips?
Old Jan 27, 2003 | 11:19 AM
89'Bowtie's Avatar
89'Bowtie
St. Jude Donor '13
Default Re: Gonna upgrade injectors...any tips? (95AquaC4)
Hello,
As far as the install is concerned. All you need is the injectors and new o-rings for the injectors. The injector should come with new o-rings, so your all set. You may later want to install an adjustable fuel pressure regulator. I beleive those injectors are rated at 3bar (43.5psi), however, the stock pressure is lower around 38psi. Thats L98 are. I haven't done anything to my LT1, so I can't say anything for sure about the facotry pressure setting and I have not measured it either. You may want to find that out via this post or look in the forum archives.
Tips:
When putting the injectos into the manifold and the rail back on the injecotrs, put a small drop of oil in the injector o-rings, top and bottom, so they slide in easier and don't tear on the aluminum. You want to consult the manual on how the releive the fuel presure on the line before you start disassembly, otherwise,
"Spilt fuel on hot engine components can cause a fire or explosion and possibly property damage, severe injury or even worse...death" Holley
Good Luck,
Victor
Old Jan 27, 2003 | 11:27 AM
rwebman's Avatar
rwebman
8th Gear
To relieve the pressure on the fuel system do the following:
1. Find the fuse box on the passanger side of the cockpit.
2. Find the fuel labeled FP (for Fuel Pump)
3. Pull the Fuse, this will disable the fuel pumps.
4. Start the engine and let it run until the engine stalls from fuel exhaustion.
5. Crank the engine over a few time just to make sure.
6. Pull the negative battery lead. (to insure from electical spark in case of some minor fuel spillage)
That should do the trick. I hope this helps.
:auto:
:chevy
Old Jan 27, 2003 | 04:35 PM
John Row's Avatar
John Row
Default Re: Gonna upgrade injectors...any tips? (rwebman)
Also, remove the gas cap. The tank sometimes retains pressure.
Old Jan 27, 2003 | 04:49 PM
95AquaC4's Avatar
95AquaC4
Default Re: Gonna upgrade injectors...any tips? (John Row)
Thanks guys! :cheers:
To Gonna upgrade injectors...any tips?
