L98 vs LT1
Do L98s have as much after market support as LT1s?
I am also trying to keep the cost in mind when it comes to mods. From what I’ve heard it sounds like parts for LT1s are generally more expensive.
Will save you time, money, energy, heart ache,
make your vehicle lighter and more economical, stop leaking, factory engine reliability, and easy street 600 to 900rwhp
L98 and LT1 were stiff learning curves for Chevrolet entering into modern era of SEQ-EFI/COP/CAD/etc... do yourself a favor and jump right into the fray at 2002 - 2008
It really depends on what you want out of the car.
You do end up mated to one body style vs another.... so maybe figure out which car you prefer first.
Overall in terms of aftermarket hardware availability, IMO the "mod-ability" of the LT1 is the same as the L98.
Heads, cams, etc... you'll be able to find what you want/need at similar prices with a similar selection.
One thing to consider is "tune-ability". Here is how I look at it when considering 89-96 cars.
89, then 94-96 are MAF cars. This means the ECU can respond to small/medium increases in volumetric efficiency on its own. What that means is you can do light engine power mods like headers, exhaust, maybe upgraded heads, maybe a tiny cam with a bit more lift (but the same duration and LSA), maybe higher ratio roller rockers etc... and you won't necessarily need a tune. You won't be getting the most out of the mods, but in terms of "mod-ability" the MAF cars having a slightly easier time for those little initial bolt ons.
1990-1993 Speed density cars really need to be retuned to see much if any improvement from your mild bolt on power mods listed above, and in fact strictly speaking you can damage a 1990-1993 Speed density car with such bolt ons in the absence of a tune because there is no way for the ECU to realize that volumetric efficiency has increased and so the car can run lean as it continues to supply fuel that corresponds to amounts of air less than what is actually getting pumped in...
Okay so tuning... fork in the road... Sticking with factory ECU or going aftermarket. If you are going forced induction most agree an aftermarket ECU is necessary. You can manage pretty wild NA builds however with the factory ECUs.
If sticking factory ECU, 1989-1993 I believe you burn chips for. To make changes to the factory ECU tune (necessary for small/medium mods on 90-93 cars and necessary for any big mods on an 89) such as a significant camshaft upgrade), you physically swap out the computer chip in the ECU. On the 1989 that is underneath the dash and a bit harder to access than 1990-1996 where the ECU is located in the engine compartment. So in terms of "mod-ability" with respect to chip burning, the 90-93 cars are superior to the 89, but then again the 89 is MAF so unlike the 90-93 cars you don't necessarily have to retune for small/medium changes.
94-96 I believe you can "reflash" the factory ECU via cable, computer, and software. That means no chip swapping. Points for "mod-ability" with respect to retuning. Arguably in terms of ease of changing the tune and or responding to mild or wild bolt on upgrades, the 94-96 cars are best... except in 1996 you get genuine OBD II so your local smog laws might start to get in the way of "mod-ability"... so 94-95 maybe comes out on top there?
All that goes out the window if you start considering aftermarket ECUs, necessary for forced induction.
Basically all aftermarket ECU options allow for flash retuning. This means easy changes to the tune, no chip swapping. Swapping in an aftermarket ECU and generally aftermarket wiring harness is in and of itself a pretty significant mod, and my knowledge here drops off post 1991, but 89-91 aftermarket ECU wiring and swap is basically the same. Technically the 89 might have a leg up on 90-91 because the Haltech system exists which allows for an aftermarket ECU with flash capability while retaining the factory wiring harness... but that is a very niche consideration.
Anyway, I hope that sorta answered your question!
If I were to "rank" those years in terms of "mod-ability" it would go as follows!
1995/1994
1989
1991/1990
1992/1993
1996 (mainly because smog)
Edited for corrections!
96 is OBD 2 and more complex to tune but when it’s done right, it can be really good.
