Spark plug circumcision
Old Jan 27, 2003 | 12:30 PM
ROADAPPLE's Avatar
ROADAPPLE
Default Spark plug circumcision
Does cutting the groud electrode back on a plug really give a noticable performance increase or should I file this procedure along with the air foil/tornado swirlley thingie?
If this procedure is valid, where can I find documentation on the steps to perform the operation?
Thanks,
Old Jan 27, 2003 | 12:34 PM
EU4RIC's Avatar
EU4RIC
Default Re: Spark plug circumcision (C44ever)
While I haven't done it myself...I have read that there are some gains to be had in performing this mod. Although I do not believe the gains to be substantial.
Old Jan 27, 2003 | 01:18 PM
93aqua's Avatar
93aqua
Do a search, a week ago some asked the same question, and someone posted a link with the answer. it did make a difference.
Old Jan 27, 2003 | 01:52 PM
jmrl98's Avatar
jmrl98
65Z01 has the procedure on his website. As far as worthiness, he swears by it, and it is interesting to observe that on the Bosch +4s, the outer electrodes do not meet over the center electrode like normal plugs. :seeya :cheers:
Old Jan 27, 2003 | 02:04 PM
ROADAPPLE's Avatar
ROADAPPLE
Default Re: Spark plug circumcision (jmrl98)
Thanks jmrl98, I tried to locate the other thread but i couldnt find it.
Old Jan 28, 2003 | 12:52 AM
85vet's Avatar
85vet
Cruise-In V Veteran
Just thought you might like to know - the motorcraft racing plugs are already cut-back.
Sorry, I meant Autolite racing plugs.
Just my .02
[Modified by 85vet, 10:52 PM 1/29/2003]
Old Jan 28, 2003 | 01:15 AM
CorvetteZ51Racer's Avatar
CorvetteZ51Racer
Could someone please post pics of this *mod*? From what I am picturing, I can't think of any reason why this should be done, and can think of a bunch why it shouldn't.
Old Jan 28, 2003 | 01:26 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Spark plug circumcision (CorvetteZ51Racer)
There's a sketch on my site.
Old Jan 28, 2003 | 05:40 PM
CorvetteZ51Racer
Default Re: Spark plug circumcision (65Z01)
I see all kinds of issues with the experimentation process here, and the only potential gain would be from having two sharp edges near each other, but the life of the plug is HUGELY diminished, and the performance of the plug will fall in the crapper right along with the lifespan. Also, screwing with the gap on the plug isn't a good idea anyway...it requires higher voltage output from your ignition system, will impose a lower limit on your rpms as controlled by the ingnition (when the system can't produce enough voltage fast enough and the engine will no longer accelerate because the ignition can't provide enough voltage to arc every time), and it hurts the lifespan of the plugs due to the accompanying change in geometry of the plug when you bend the ground electrode.
Old Jan 28, 2003 | 11:17 PM
FlyboyZR1's Avatar
FlyboyZR1
Anyone have before/after dyno results with cut-back plugs? I know people swear by it, but I'm curious to see the numbers... :)
Old Jan 29, 2003 | 09:29 AM
ELEVENS's Avatar
ELEVENS
Sounds painful!
Old Jan 29, 2003 | 10:33 AM
ROADAPPLE's Avatar
ROADAPPLE
Default Re: Spark plug circumcision (ELEVENS)
Helmet or anteater? :jester
Old Jan 29, 2003 | 10:40 AM
ELEVENS's Avatar
ELEVENS
Well, here goes another perfectly good thread into the gutter! :bb :jester :cheers:
Old Jan 30, 2003 | 11:15 AM
mr.beachcomber's Avatar
mr.beachcomber
Cut-back spark plugs are a throwback to the early sixties when we used to cut back the spark plug's ground electrode to expose more of the spark to the air-fuel mixture in the combustion chamber just like the real racers that used J-gap spark plugs from Champion for racing. Besides cutting back the ground electrode, we used to close the gap from .035" to .028" to lower the voltage requirements to jump the gap thus ensuring adequate spark above 5800 rpm for our high compression (11:1) small blocks. (Transistorized ignition systems were still a couple of years away so most of us used dual-point distributors to increase the dwell time for our high performance ignition coils. Retaining the stock gap almost guaranteed a high rpm misfire!) :eek:
Given the current availability of multiple-spark ignition systems, better spark plugs, and the relatively mild compression engines that most of us use today, the use of cut-back spark plugs is passe in street machines. :sleep:
If you do want to use cut-back spark plugs, remember to index the plug such that the open gap is facing the intake valve to maximize the exposure of the air-fuel mixture to the spark. How much more HP/torque this will give you than simply indexing your current plugs is debatable if you are using slant plug heads. On straight plug heads, I have seen a 5 HP increase above 6000 rpm on my blueprinted 1970 LT-1 engine (11.25:1 compression). YMMV! :)
To Spark plug circumcision
