outer window seal
Old Jan 28, 2003 | 08:44 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Default outer window seal
just got the outer window seals for the doors. anyone got any helpful hints to re and re them?? thanks :confused:
Old Jan 28, 2003 | 08:52 PM
FD2BLK's Avatar
FD2BLK
Default Re: outer window seal (dankai)
I did this about a year ago its not to bad all I can remember is roll down your window remove your door panel and you will need a small philips head for the screw nearest the front of the door. I cant remember to much and that is a good thing it must have been prety uneventfull
Old Jan 28, 2003 | 09:12 PM
chucks88's Avatar
chucks88
Default Re: outer window seal (ejfagala)
It's pretty much straight forward. However just when you think you've got all of the screw removed to remove the door panel another one appears, especially inside the door handle. You'll have to drill out the old rivets and your gonna need a pop rivet gun to put the new ones in.
To outer window seal
