Open this FLIPPIN' HATCH!!!
Old Mar 29, 2024 | 11:31 PM
Butta Mylk's Avatar
Butta Mylk
4th Gear
Default Open this FLIPPIN' HATCH!!!
I have recently purchased a '87 Vette. I cannot get the back hatch to open. Someone has already done a mod to the wire that is the back up release but I can still not get it to pop open. I will gladly replace it, if I can get into it. Please give me any ideas before I lose my mind. Tomorrow I am going to do a headlight upgrade. I will post pics.
Old Mar 30, 2024 | 07:00 AM
ex-x-fire's Avatar
ex-x-fire
Have someone push down on the glass while you pull the release.
Old Apr 1, 2024 | 01:18 AM
Butta Mylk's Avatar
Butta Mylk
4th Gear
Tried that, but didn't work. I did install the headlights though. Maybe I can flick the hatch with a flathead screwdriver.
Old Apr 1, 2024 | 08:02 AM
bjankuski's Avatar
bjankuski
There is an emergency pull cable on the latch, dig around back by the latch and pull the cable to pop the hatch open.
Old Apr 1, 2024 | 08:55 AM
ThomasR's Avatar
ThomasR
Slide your hand under the cargo shade on the passenger side and you'll find the release cable. Use vice grips if you need to pull the cable. You will not be able to release the latch with a screw driver.
Old Apr 1, 2024 | 09:07 AM
ThomasR's Avatar
ThomasR
https://www.corvetteforum.com/forums...post1606487370
I ended up replacing my hatch release solenoid because the coil was bad. I took it apart first hoping it was a bad ground and I could fix it. I hope these photos help show the release and give you an idea of what you're up against.
Old Apr 1, 2024 | 09:26 AM
Butta Mylk's Avatar
Butta Mylk
4th Gear
Someone had already put a ring on that release cable. I've pulled and pulled and pulled it. Even the release cable won't work.
Old Apr 2, 2024 | 02:34 AM
JETS C3-C4's Avatar
JETS C3-C4
Have you tired his suggestion?
Frustrating but don't give up. Congrats on your new to you Vette and welcome to the forum where you will get lots of help from the members.
Old Apr 6, 2024 | 12:48 PM
kael's Avatar
kael
Finalist 2020 C4 of the Year - Unmodified
Hoping this ring is to the cable UNDER the shade, not the incorrect item the pic is pointing too.
Did you pull to the RIGHT (PASSENGER) SIDE of the car? Don't pull to the front.
Old Apr 6, 2024 | 01:50 PM
ChumpVette's Avatar
ChumpVette
The arrow is pointing to the attachment point of his extended cable with the loop. Not to the Targa top latch.
Old Apr 7, 2024 | 06:18 AM
kael's Avatar
kael
For those of us that already know what it's referring to.
For someone clueless as to what they're looking for, misleading.
To Open this FLIPPIN' HATCH!!!
