PERFORMANCE CHIP FOR 84
Old Jan 29, 2003 | 02:58 PM
ink4lfe's Avatar
ink4lfe
Default PERFORMANCE CHIP FOR 84
WHAT WOULD BE THE BEST PERFORMANCE CHIP I COULD GET FOR MY CAR, AND WHERE DO I GET IT. :cheers:
Old Jan 29, 2003 | 03:11 PM
vader86's Avatar
vader86
Default Re: PERFORMANCE CHIP FOR 84 (ink4lfe)
Performance chips do nothing in the way of real performance on a stock engine. All they really do is advance timing and make your fans come on sooner.
Once you have real mods: heads, intake, cam; theyll be beneficial, but even then only a custom program will help you.
Old Jan 29, 2003 | 03:13 PM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
I put a Hypertech thermo master in my 84
Old Jan 29, 2003 | 03:42 PM
yoslambo1@cs.com's Avatar
yoslambo1@cs.com
ben there done that....i had one with the 160 thermo & it really didnt help much! :nonod:
Old Jan 29, 2003 | 04:43 PM
quiksilver458's Avatar
quiksilver458
If you want a big performance increase out of your CFI, get your hands on a 7747 ECM and install that in the car. You will be able to have custom chips burned that do far more than any hypertech chip does. :steering:
Old Jan 29, 2003 | 09:37 PM
CFI-EFI's Avatar
CFI-EFI
I installed a Hypertech stage II and a 160* thermostat in my '84 and it slowed down. I tested making back to back runs at the strip. Two initial runs on the stock chip, two runs on the Hypertech, and the rest of the night on the stock chip. The Hyper runs were the slowest of the sesson. Only 1/2 to a full tenth, but why would you spend money to go slower? I sent it back. The fan on an '84 is not ECM controlled. the only difference I observed, was less "hunting" on the OD engagement. It wasn't THAT bad to start with. From MY experience, I say, save your money for something that works. Other people and/or other chips MAY provide better results. Good luck, and...
RACE ON!!!
PS. WithOUT touching the long block, I have shaved, TWO full seconds off my ETs, so it's not like I've given up easily.
[Modified by CFI-EFI, 8:45 PM 1/29/2003]
To PERFORMANCE CHIP FOR 84
