Severe Loss in Power / Rough idle
Old Apr 13, 2024 | 11:53 PM
Wasbas's Avatar
Wasbas
4th Gear
Default Severe Loss in Power / Rough idle
So I put vortec heads on my 85 vette, L98 with quadrajet, and after running it the first couple weeks with 91 octane fuel it was amazing and no issues. I went ahead and jumped up to 93 octane to see if it would make it run any better. Since then the car has had nothing but issues idling as well as power loss. After sitting in the parking lot for about 5 minutes I revved the car up a touch and shot a flame straight out of the top of the carb. Anyone know if running the 93 would make the car bog down and have power issues? Any help would be much appreciated.
Old Apr 14, 2024 | 07:18 AM
bjankuski's Avatar
bjankuski
The fuel change is not the issue unless it was contaminated fuel. Sounds like an ignition issue. Check the timing, plugs, wires, cap.
Old Apr 14, 2024 | 08:31 AM
FostersPerformance's Avatar
FostersPerformance
Check to see if your distributor hold down bolt loosened up....
Old Apr 14, 2024 | 09:27 PM
Corvette_Dez's Avatar
Corvette_Dez
Definitely sounds like a timing issue.
To Severe Loss in Power / Rough idle
