replacing block in my 88 C4
Old Apr 24, 2024 | 03:03 PM
Vette 460's Avatar
Vette 460
Default replacing block in my 88 C4
I have a cracked block leaking coolant and need to replace it. The engine is built up- Cam, heads, etc. so I want to be able to switch all the goodies from my block.
Do I need to find a specific block to the 88 block or can I use other small block chevys? I have a SB from the mid 70's I could use, but want it to be able to fit in just like the original.
Old Apr 24, 2024 | 03:19 PM
FostersPerformance's Avatar
FostersPerformance
Needs to be a one piece rear main seal, roller lifter block otherwise all your good parts wont work
Old Apr 24, 2024 | 04:19 PM
vader86's Avatar
vader86
A 1-piece rear main and roller block would have everything you need basically.
Now there are kits to convert non-roller blocks over, but if you want everything to go like before, best to get the newer block.
Old Apr 25, 2024 | 04:12 AM
Vette 460's Avatar
Vette 460
Thanks both of you, good advice. I'll find a newer block.
Old Apr 25, 2024 | 08:24 AM
'78CorvetteS.A.'s Avatar
'78CorvetteS.A.
And the block from the '70s will likely have a lefthand oil dipstick...the correct 1 piece rms block will have it on the righthand side, you'd also want the newer block for your oil pan to fit/work! Check any local machine shop, they should have what you need👍
Old Apr 25, 2024 | 08:48 AM
Vette 460's Avatar
Vette 460
Will do. Good idea.
Old Apr 25, 2024 | 09:14 AM
'78CorvetteS.A.
Originally Posted by Vette 460
Will do. Good idea.
Also, if you have them do the machine work, they would likely sell you the core block for cheap! Whoever does your cylinder work, make sure torque plates are used...these simulate cylinder heads bolted on during the machining process! They should also be able to tell how much they'll need to bore to clean it up, make sure this number will work with your pistons, if you're planning on reusing and just get some new rings...re-ring kit with all the bearings, new oil pump, brass soft/freeze plugs, etc! One last thing, make sure they take out all oil galley plugs in the beginning (during all hot tanking and machining steps) and that they all get reinstalled at the end!!! Good luck👍
Old Apr 25, 2024 | 09:56 AM
Vette 460's Avatar
Vette 460
Thanks for your help, sounds good. Appreciate it.
Old Apr 25, 2024 | 09:57 AM
bjankuski's Avatar
bjankuski
As noted above you need a new roller block and that would be 1987 and newer blocks.
Old Apr 25, 2024 | 10:41 AM
Vette 460's Avatar
Vette 460
How new can I go to be the same?
Old Apr 25, 2024 | 02:45 PM
RWDsmoke's Avatar
RWDsmoke
Before GM went to all LS motors in the late 90's or early 2000's , there were millions of trucks and vans with that block.
Old Apr 25, 2024 | 02:59 PM
Phobos84's Avatar
Phobos84
The easiest thing to do is lookup what the closest self service salvage yard is to you. Most of these companies will list the VIN numbers for there vehicles that are on the yard. So I would look for a late 90's to 2001 Express van. Look at the vin. If the 8th digit is an "R" then this is a four bolt main 350 that will suit your needs. Vans like this are a little easier to pull motors from in a junk yard. Just pull the motor and the trans together. If you want buy the trans and sell it. That's the later generation 4L80e in 2wd. They sell for around $900 on eBay all day long
Old Apr 25, 2024 | 03:45 PM
Vette 460's Avatar
Vette 460
Thanks, Tomorrow I'll go on a hunt at the Salvage Yards.
Old Apr 25, 2024 | 04:20 PM
FostersPerformance
Mercruiser still uses these blocks to this day. If i had one that wasnt freeze damaged id sell you one cheap.
Old Apr 25, 2024 | 05:32 PM
Vette 460's Avatar
Vette 460
I did boats for 30 years, have a few connections, I'll call them.
Old Apr 26, 2024 | 01:03 AM
Gale Banks 80''s Avatar
Gale Banks 80'
My Machinist sold me a 880 Vortec 4 Bolt Block for $400 That had the standard sized Bores Honed, Ground for a 383 Crank, Hot Tanked washed and Cam Bearings installed. In other words he sold me his time and gave me the Block. No Junkyard needed.
Old Apr 26, 2024 | 07:07 AM
Vette 460's Avatar
Vette 460
Starting my search today, I'll do machine shops first..... Thanks!
To replacing block in my 88 C4
