95 Corvette th350 trans mount
Old May 8, 2024 | 02:23 PM
Slowvette95's Avatar
Slowvette95
8th Gear
Default 95 Corvette th350 trans mount
Anyone ever swapped a th350 to a 95 Corvette? Curious if anyones made the bracket for it yet or know of anyone who has.
Old May 8, 2024 | 08:36 PM
rklessdriver's Avatar
rklessdriver
If you use a mid length 9" output shaft length TH350, you can buy an adapter/spacer that allows you to bolt the C4 700R/4L60 tail housing to the TH350. Everything bolts up to the stock C beam just like stock.
https://www.summitracing.com/parts/add-50-8506
I used this setup on my C4 drag car when it still had IRS. Works great.
Will
Old May 9, 2024 | 07:30 PM
Slowvette95
8th Gear
Will
Okay will I need anything else? About to order the adapter
Old May 14, 2024 | 01:18 AM
rklessdriver
Nope it's as easy as modifying a car gets.
Will​​​
To 95 Corvette th350 trans mount
