84 corvette just randomly dies
Old Jun 16, 2024 | 11:27 AM
84cfour's Avatar
84cfour
7th Gear
Default 84 corvette just randomly dies
I have a 84 corvette that dies on me at random times, sometimes right after start up , sometimes while driving ,sometimes while at a stop or coming to a stop . It always starts right back up.
Very annoying , I have way to much money in this thing for it to be acting as retarded as it does all the time .
Old Jun 16, 2024 | 11:32 AM
mike1111's Avatar
mike1111
check fuel pressure 13psi. on mine the fuel hose from the pump to fuel pick up was cracked. that's all I got
Old Jun 16, 2024 | 11:39 AM
84cfour's Avatar
84cfour
7th Gear
alrighty will do , I want to also add that sometimes it will run fine for a few days like nothing is wrong then soon enough it will do it again
Old Jun 16, 2024 | 07:56 PM
typical boomer's Avatar
typical boomer
This may sound really dumb (take it easy on me arbee) but if you have a lot of keys on your keyring could the weight combined with a 40+ year old ignition switch be enough to move the switch and stop the engine?
Old Jun 16, 2024 | 08:48 PM
2011KLR's Avatar
2011KLR
Wasnt there a class actton against GM in the 90s or so about keys causing something similiar?
Old Jun 16, 2024 | 08:52 PM
flannel_man's Avatar
flannel_man
Cruise-In VI Veteran
When you say randomly, are you certain it's random?
Reason I ask is there is one intersection near my apartments that would always kill my 84. If I had to stop at the light I would stop way away from the white line or I'd be pushing it across the street and then it would fire right back up. If the light was green the car would die and I'd coast thru it and the engine would refire when I rolled far enough away from the problem. All I can assume after all those years is there was something going on with the EMF of the utilities under the road right there and my ignition system was affected. Didn't affect my roommates' or coworkers' vehicles
​​​​​​If it is completely random tho, like they mentioned check fuel pressure. Yours sounds like a fuel flow problem. Maybe the in tank sock is mostly clogged. Maybe even do a fuel filter change, they are as cheap as an oil filter. Otherwise you may need to ohm out the pickup coil and check your tumbler for excessive wear
Old Jun 16, 2024 | 10:52 PM
typical boomer
There was this one.
https://www.vox.com/2014/10/3/18073458/gm-car-recall
Old Jun 17, 2024 | 12:15 PM
84cfour's Avatar
84cfour
7th Gear
probably a dumb question but how and where do I test the fuel pressure on a 84.
Old Jun 17, 2024 | 01:36 PM
ex-x-fire's Avatar
ex-x-fire
An egr valve thats stuck open will cause stalling but not while driving.
Old Jun 17, 2024 | 01:44 PM
mike1111's Avatar
mike1111
can use nipples and rubber hose
Old Jun 17, 2024 | 04:14 PM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
Just wondering, since you didn't mention it. Do you EVER get a CEL when this happens?
Old Jun 17, 2024 | 04:21 PM
84cfour's Avatar
84cfour
7th Gear
I never get a cel when it happens
To 84 corvette just randomly dies
