Injector flow test results
Do you trust both sensors?
How did you determine that the right bank is running 0.8 AFR richer? Do you have two widebands, or did you swap the positions from left to right or vice-versa?
This data has pretty good WB/MB correlation. You can see that the rich and lean peaks and valleys are in sync. Interestingly during closed loop cruising, the WB is always running about 0.1 AFR richer (on average) than the target AFR with both adapted for E10 fuel assuming a 14.12:1 stoichiometric ratio.
https://datazap.me/u/tequilaboy/160-...1020-1052-1099
I think this car is set up with the PLX WBO2 reading from both banks or somewhere downstream of the LPE headers y-pipe merge. I will check with the owner for details. Car also has a super ram intake with Prochager p600b and 42 lb/hr injectors.
Different car, different fuel (f-body 5 litre with tpi intake and Procharger in the UK. Innovate WBO2 location unknown, but assumed to be right bank): https://datazap.me/u/tequilaboy/feli...4902-4931-4745
This 2nd car is right on the money regarding the target AFR, NB and WBO2 correlation during closed loop (14.72:1).
The data from both of these cars does not indicate any bank to bank discrepancy or any significant WB/NB discrepancy. I wonder if you have a fuel pressure differential or voltage offset from bank to bank.
Even on my Miniram when I had the split BLMs it would only last up to about 1500 rpm.
