Solid Motor Mounts?
Old Jun 30, 2024 | 01:19 AM
fast.asleep's Avatar
fast.asleep
Default Solid Motor Mounts?
Does anyone make solid motor mounts for the early C4?
Old Jun 30, 2024 | 01:22 PM
dizwiz24's Avatar
dizwiz24
i bought some from forum member churchkey about 13 yrs ago
he was building them
Old Jun 30, 2024 | 03:20 PM
fast.asleep
thanks, I found that thread. Later in that thread it was mentioned that he no longer makes them. I didn't need them back then but wished I bought a set. Hell I wished I bought a forced air licence plate insert 20 years ago too.
Old Jun 30, 2024 | 06:33 PM
jmgtp's Avatar
jmgtp
I have Prothane mounts which are (nearly) solid. They are beefy machined aluminum with a poly bushing. Really nice pieces, really pricey though. Some extra noise transmitted, didn’t notice extra vibration.
Old Jul 1, 2024 | 09:56 AM
93 ragtop's Avatar
93 ragtop
Keep in mind, the above replies are for the latter C4 with a LT1 engine. The mounts are different.........
Old Jul 1, 2024 | 11:30 AM
dizwiz24's Avatar
dizwiz24
learned something new
thanks for the info
Old Jul 1, 2024 | 03:22 PM
AZSP33D's Avatar
AZSP33D
I believe Speedway carries solid steel mounts that work for L98, got a set several years ago but returned, didn’t like the design… and quite a few more options on solid LT1 mounts. Some 3/16 plate bent into a U shape and holes drilled would probably work for the L98, or even modified OEM mounts. Chunk of billet with holes drilled tapped may work on an LT1.
To Solid Motor Mounts?
