Testing ,Testing Testing
Old Jul 16, 2024 | 12:20 PM
signify's Avatar
signify
Default Testing ,Testing Testing
When testing a battery how large a load should be placed on the battery to get a accurate test . Is 100 amps adequate or more? This is a 12 volt battery 4 years old if that makes a difference?
Old Jul 16, 2024 | 01:52 PM
2011KLR's Avatar
2011KLR
i bought a tester from Harbor Freight. (i have a lot of batteries to watch over)
Unless you just want to know the answer above, just pop it out and take to a parts shop. They'll test it for you.
Old Jul 17, 2024 | 07:47 AM
jmeyer58's Avatar
jmeyer58
A fully charged battery should be tested at 1/2 the Cold Cranking Amps for 15 seconds while observing the battery voltage. The voltage should not drop below 9.6 volts during the test. If it does, replace the battery.
Old Jul 17, 2024 | 08:47 AM
signify's Avatar
signify
Thanks i know jmeyer is correct
Old Jul 17, 2024 | 09:04 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Load style battery testers are basically outdated…the capacitive type testers is what is used today…you can get this one for $135.00 from Amazon.
Old Jul 18, 2024 | 03:52 AM
JETS C3-C4's Avatar
JETS C3-C4
I bought one but without the printout function. Usually dealer uses that to give to the customer.
The one I have is Topton model BT50. Topton sells this model on ebay direct and less than $30. Amazon has it for $49.99.
Topton has quite a few different models to choose from. I am satisfied with mine. My .02
To Testing ,Testing Testing
