I need help
Old Jul 27, 2024 | 02:55 PM
1995 lt1 corvtte 16's Avatar
1995 lt1 corvtte 16
3rd Gear
Default I need help
I just had my optispark distributor replaced and now I have a misfire and my engine shakes and doesn’t have much power. I check my spark plug wires and they all have spark. I believe I have a misfire. Any suggestions?
Old Jul 27, 2024 | 03:56 PM
Whaleman's Avatar
Whaleman
First thing is to check for codes. Dan
Old Jul 27, 2024 | 04:08 PM
ChumpVette's Avatar
ChumpVette
Did you replace the opti yourself?
Old Jul 29, 2024 | 01:18 AM
1995 lt1 corvtte 16
3rd Gear
no i did not.
Old Jul 29, 2024 | 01:49 AM
93TALT4A4's Avatar
93TALT4A4
Double check the wires. Possible a wire has been crossed. Was anything wrong with the old optispark? Factory optisparks can be cleaned and work fine. Aftermarket optisparks are notorious hunks of crap.
Old Jul 29, 2024 | 04:06 PM
1995 lt1 corvtte 16
3rd Gear
Originally Posted by 93TALT4A4
Double check the wires. Possible a wire has been crossed. Was anything wrong with the old optispark? Factory optisparks can be cleaned and work fine. Aftermarket optisparks are notorious hunks of .
The opti went out completely I was driving and my engine cut off and it would crank but wouldn’t start. I cannot figure out how to see the driver side distributer where the plugs connect without taking everything apart again any tips?
To I need help
