Vats code 46
Old Jul 31, 2024 | 12:28 AM
Daily_C4's Avatar
Daily_C4
Default Vats code 46
Alright so I know that it’s a vat’s malfunction and my no crank no start, but since it’s a 1990 corvette the vats is programmed into the ecm. I don’t own a fsm for my vette yet, anyone with some knowledge is greatly appreciated.
Old Jul 31, 2024 | 01:42 AM
ChumpVette's Avatar
ChumpVette
If you have a second key, try that first.
But basically code 46 the CCM and ECM are not communicating on circuit 229
Old Jul 31, 2024 | 08:50 AM
WVZR-1's Avatar
WVZR-1
If you have the car titled, you can take the registration or title + corresponding personal ID to a GM dealer and ask that they do what's called a 'Key Call'. For a '90 I believe it would include original key numbers and also the code for the 'resistance'. Dealers will NOT do it without ID and they do generally charge for it. If the key cylinder has ever been replaced then that key code wouldn't work but 'very seldom' is the 'resistance' ever changed. I believe you could rely on the resistance. To confirm the key code have them or a locksmith cut a brass 'work key' and confirm rotation before doing a resistance key.
Old Jul 31, 2024 | 01:04 PM
Daily_C4's Avatar
Daily_C4
Well a little while back I had a resistance problem and had my cylinder replaced, could it possibly be because i didn’t ‘program’ my key/key cylinder
Old Jul 31, 2024 | 01:06 PM
Daily_C4's Avatar
Daily_C4
I had tried my second key, is the no communication a problem such as a dead wire or no electrical signal within the wire?
Old Jul 31, 2024 | 01:07 PM
WVZR-1's Avatar
WVZR-1
If you changed the cylinder it would have come with a 'work key' to only rotate and you should have had a new resistance key cut to that mechanical cut. Are you still just trying the key that came with it? Do you have your old key still? If you can measure the resiatance of the old key get a new key cut to match the mechanical of the new and the resistance value of the old.
Old Jul 31, 2024 | 01:22 PM
Daily_C4's Avatar
Daily_C4
No, I tested my ‘work key’ to make sure my cylinder rotated then got my new keys cut, same resistance and all.
Old Jul 31, 2024 | 01:39 PM
WVZR-1's Avatar
WVZR-1
Did it crank and run ever with the new cylinder and keys?
Old Jul 31, 2024 | 01:51 PM
Daily_C4's Avatar
Daily_C4
No, I didn’t get a crank or a start? Got any ideas?
Old Jul 31, 2024 | 01:59 PM
WVZR-1's Avatar
WVZR-1
If it ran previously(with old cylinder) then either the connector at the steering column base isn't connected, you've torn the wires to the bottom of the column while routing them OR a bad resistance key. Was this a 'For Hire' repair or a DIY?
Old Jul 31, 2024 | 02:03 PM
Daily_C4's Avatar
Daily_C4
DIY, I inspected the column before and after, shouldn’t have any torn wires and my cylinder is connected properly.
Old Jul 31, 2024 | 02:09 PM
WVZR-1's Avatar
WVZR-1
If you bought your cylinder 'local' ask them to maybe loan you for diagnostics another. Connect the 'loaner' to the connector at the base of the column, insert a known good resistance key in the cylinder and use the key in the column now for crank. That's a very simple bypass for testing. If a tourist had an issue in the past we would suggest this vs a steering column disassembly to do a repair if their pockets were light! The 'loaner' doesn't need to rotate it just need to provide the resistance through the connector.
Use a resistor to bypass if that works. How did you determine the key resistance you used was correct? Do you have the old key(s) still? Use that key in the 'loaner' cylinder!
Old Jul 31, 2024 | 02:12 PM
Daily_C4's Avatar
Daily_C4
My issue with that is I wasn’t able to buy locally and had it shipped since I live on one of the Hawaiian islands
Old Jul 31, 2024 | 02:18 PM
WVZR-1's Avatar
WVZR-1
Do you still have the old cylinder? If the wires aren't torn or an issue you could check the resistance of the connection with a meter. You could try that. Check the resistance of the key using the wires at the base of the column. How do you know you had a correct key resistance cut?
Old Jul 31, 2024 | 02:20 PM
Daily_C4's Avatar
Daily_C4
Checked both my bought keys and my original cylinder keys with a multimeter. I’ll try the old cylinder in a bit.
Old Jul 31, 2024 | 02:41 PM
ChumpVette's Avatar
ChumpVette
Is there any other codes besides a 46?
Key in ignition - is security light on solid or off?
Old Jul 31, 2024 | 02:43 PM
Daily_C4's Avatar
Daily_C4
Key in on position displays a solid security light
To Vats code 46
Old Jul 31, 2024 | 02:53 PM
ChumpVette's Avatar
ChumpVette
So resistance does not match expected value in CCM.
Original key in cylinder, is security light on or off?
Is this a new car to you?
Did it ever run previously?
How was VATS code determined off your old key
Old Jul 31, 2024 | 03:05 PM
Daily_C4's Avatar
Daily_C4
New cylinder original key won’t fit the new cylinder
Corvettes aren’t new to me but the c4 vats is very new to me
it ran previously but it wasn’t reading the keys resistance correctly triggering vats so i replaced the cylinder. Prior to replacing the cylinder I had one good start pulled it into my garage then it went dormant, no crank no start. That’s when I changed my ignition cylinder. Prior to this code I had the active code where the injectors weren’t getting the signal to pulse but now it’s the VATS malfunction.
Old Jul 31, 2024 | 03:10 PM
ChumpVette's Avatar
ChumpVette
So how was the VATS code read off the old key?
And any other codes listed? I would expect a 54 as well.
