Broken CCM?
Old Aug 21, 2024 | 10:17 AM
sheriffjim's Avatar
sheriffjim
Default Broken CCM?
I have a 91 6spd. I was driving it the other day with the AC on and stalled the engine. After the stall, the AC head unit has gone completely dead (no readout/no green lights but the backlight does work), and the fuel economy read 0 constantly on the dash. I also lost all control of the trip monitor stuff, the buttons to change the information quit working. The dash flashes sys, but the engine runs and drives fine. I also noticed that the radio and lights shut off immediately when you turn off the key, they won't stay on until you open the door.
Today I disconnected the battery, and when I reconnected it, my odometer had reset itself! 0 miles! This has me concerned that my CCM is fried.
Does this mean I need a new CCM, or is there something else I should check first? If I do need a CCM can I get the original mileage programmed back into it?
Old Aug 21, 2024 | 10:22 AM
sheriffjim's Avatar
sheriffjim
Now the dash has gone completely dead and I have no crank . Of course it happened in a random parking lot and not at home
Old Aug 21, 2024 | 10:23 AM
WVZR-1's Avatar
WVZR-1
I doubt the CCM is 'busted'!
Do you have the FSM(Factory/Field Service Manual)? If you do go to the 8D section and start diagnostics.
Old Aug 21, 2024 | 10:37 AM
sheriffjim's Avatar
sheriffjim
I let it sit for a minute and turned on the lights, which lit up the dash. It is now again showing the correct mileage and it did start. Other issues are still going though.
I do have an FSM however I am not at home at the moment. I doubt the ECM is not causing an issue because the engine runs normally. I replaced it about a year ago as well. The issue seems to be with the non-engine stuff, interior things. I believe that is controlled by the CCM. I went through the fuses and didn't find anything although I can look again later. Diagnostic mode is not working, so I can't read any codes. I can try plugging into TunerPro but that will have to wait until I get home.
I'm not set on the idea that the CCM needs to be replaced, but I do believe that whatever is going on is related to the CCM.
Old Aug 21, 2024 | 10:58 AM
sheriffjim's Avatar
sheriffjim
TunerPro won't even try to connect. I don't think it even knows its plugged in. Pretty sure my ALDL is not working.
Old Aug 21, 2024 | 11:01 AM
IHBD's Avatar
IHBD
Pro Mechanic
The CCM and HVAC are not interconnected, but share a common fuse. "A/C"
The other two fuses for CCM power are CCM and LCD
Your symptoms suggest that the CCM is not fully powering ON. The A/C fuse provides the "hot in run" power to the CCM. Be sure that fuse is good and it is tight and not corroded.
The SYS message indicates there is an active, Current code in the CCM. Even if the buttons don't work, the diagnostics should. Jumper A&G, turn the key to RUN, watch the codes. The first group in Module 1 are the CCM codes. You're interested in any C codes except C12.
And I know that by now you have checked and rechecked both battery cable connections at the battery, right?
Old Aug 21, 2024 | 11:43 AM
sheriffjim's Avatar
sheriffjim
I can't get the codes from the ALDL. I tried jumping the pins and connecting to TunerPro and both were unresponsive. I'm sure I did it right I've probably done it 100 times. So much I keep a paperclip in the center console specifically for that purpose. I have checked the battery connections, its all good there. I checked the A/C fuse and it was fine, but I'll check it again and may replace it regardless if I have the right amperage on hand. I need to check the other CCM fuses.
Old Aug 21, 2024 | 11:58 AM
IHBD's Avatar
IHBD
Pro Mechanic
In a 1991 there are 5 pairs of terminals that will "pull codes". A&B, A&C, A&G, A&H, A&K. Depends on which system you want the codes for.
Which pins?
Can Tunerpro read CCM data? I know squat about Tunerpro, but I've seen others (perhaps you?) on here say that Tunerpro turns off the CCM so it can 'see' ECM data.
A&G are the CCM. A is the ground, top right. G is CCM, bottom left. Use your paper clip and report back.
Old Aug 21, 2024 | 01:08 PM
sheriffjim's Avatar
sheriffjim
Which pins?
I jumped A and G. You are right about TunerPro. As far as I know it can only read engine codes and ECM data. My reason for mentioning it was because my ALDL appears not to be working. I do believe the ALDL has to pass through the CCM to read any data, which is why this concerns me regarding the CCM. From what I understand the CCM is like a central computer that connects all the other systems in the car, such as the ALDL and ECM. I may be wrong about any of this but this is my understanding.
I'll try the fuses, and I'll try to jump the ALDL again. Any other suggestions you may have I will be happy to try as well. I won't be able to until this evening however, and I may wait until tomorrow because its a late night for me tonight with an early morning tomorrow.
Old Aug 21, 2024 | 09:25 PM
sheriffjim's Avatar
sheriffjim
It was the A/C fuse. I feel very silly for having missed that the first time, and for having made a whole post without doing the proper diagnostics first. I did check the fuse, but apparently didn't look at it hard enough. It was kind of hard to tell. I stole the heated mirror fuse and its all working now. Sorry for wasting your time with this issue, I got scared over the odometer resetting itself and wasn't in a place where I could do much. Thanks for all the helpful insight.
To Broken CCM?
